What kind of wire for my RT600I's ?
adman2134
adman2134 Posts: 4
I just got some RT600I's and I am planning on hooking them up to a JVC RX-8020VBK. What kind of wire would be the best? Any input would be great. Thanks.
Post edited by adman2134 on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited August 2002
    Speaker wire should work fairly well..... ;)
  • BRAD-TX
    BRAD-TX Posts: 25
    edited August 2002
    Speaker wire???
    So thats the reason I can't hear anything out of my speakers! Speaker wire, what a thought.
  • haroo
    haroo Posts: 83
    edited August 2002
    home brew...
    cat 5!
    --MARANTZ SR18ex 140wpc x 5 (high current/direct amp)thx-ex "ultra"
    electrohome tube amp 15watt. pr channel(aprox.1955a.d.) for 2 channel audio{recently recapped& tubed-5ar4power rect. & 12au7)
    -kenwood amp(km-996/140wpc(used for 7.1 rears(thx ex)
    -toshiba dvd video/audio player(progressive scan) sd-4700
    -sony sacd cd player scd-xe670
    -nakamichi "music bank cd player "6+1disk(20bit dac)
    -toshiba hifi vcr (v3 pro head)
    -motorola digital cable box
    -RCA 32' "home theater" PIP tv
    -polk RT800i x 2 (mains) ~bi-wired
    -polk sc400i x 1 (center) ~bi-wired
    -polk fx300i x 2 (side fx) ~di-pole
    -polk r10 x 2 (rears)
    -polk pws250 (powered sub)
    -2x173ltr(48"-16")sono subs(powered by kenwood kr-7200 250watt & w/ audiosource EQ (model eq eight/series II)
    -Thorens td-166 mk II/Grado silver fs1
    -Thorens td-160/empire 66cart
    -Dual 601
    -D.I.Y. carfea "little big horns"-(pioneer full range 8" & fostex 4" compression horn tweaters
    -sony (ps1)
    -sony (ps2)
    -haroo, "GOD gave you the gift of sound, Your gift to God is what you do with it!"
    "marantz haroo"
  • mantis
    mantis Posts: 17,323
    edited August 2002
    For the rt600i's,Id look into Monstercable mcx wires, nicely built,good sound quality,and won't break the bank.Should match your system well.
    Dan
  • adman2134
    adman2134 Posts: 4
    edited August 2002
    Thanks mantis for the input. I will see if I can find that kind of wire.
