Def Tech is cranking it up! (monster, 175 pound sub)
VR3
http://www.definitivetech.com/loudspeakers/subwoofers/subwoofers.html#trinity
Dual 14" Woofs
Four 14" PRs
2000 Watts
128 db at 20 Hz and 116 db at 16 Hz
Neat.
Dual 14" Woofs
Four 14" PRs
2000 Watts
Neat.
Post edited by VR3 on
wow. Deftech seems to be sticking with their space saving subs. Going up.
I've heard their cubes and am impressed.
No idea how far def tech will go. Can't wait to hear this one.
ChrisReceiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt -
Man that is hardly...space saving...
Its like a rectangular SVS...
18x18x32 ish... 175 pounds... haha
Its the kind of price point Polk should be trying to get back into, IMO... (On all things)- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
2000 watts, dual 14" subs and it can only hit 128 db?
Isnt that a little low?
A 10" car sub can hit mid 130's with as little as 300 watts. Whats the difference?polkaudio sound quality competitor since 2005
Umm Macelod...
Thats TWENTY HERTZ... lol - not 50hz...
Hitting 130 db at 20hz is darn impressive.
You're looking at MASSIVE SPL around 50hz...
Also, comparing a car sub (inside a small cabin) to a home sub (inside a house) is fairly hard to do. You will rarely see above 130db in the home...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
You cant hear 20 Hz! I guess you could feel it maybe.polkaudio sound quality competitor since 2005
You cant hear 16hz either..
20hz and below is COOL, very cool to experience...
I like my 15hzish response!
If you cant hear it how do you know when youre feeling it!?!
Yall know...
Everything is shifting in the room... you cant hear a thing.. but everything is just rattling around you...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
That would be nice to experience. Im sure its not cheap, nor easy to get that tho.polkaudio sound quality competitor since 2005
Not really...
The Bottom of the line SVS goes subsonic (18hz tune point) - about 15hz extention in a modest size room.
Every SVS subwoofer model can subsonic.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Is it more the tuning and construction of the enclosure or is it the sub that designed specifically to go sub-sonic?polkaudio sound quality competitor since 2005
The enclosure has alot to do with it...
You need a large enclosure for effeciency, a woofer with high excursion, and a nice amp - and yes, the tuning for it to go that low...
Its takes a combination of things to reach those notes. The problem with alot of OEM subwoofers and why they cant reach below 30hz most of the time (POLK!!) is because they use small enclosures and modest amps.
If they want to use a small enclosure and get that response, your looking at TONS of excursions and just a massive amp...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Gotcha.
Do they make passive enlosures so you can stick the amp on it you want? All the subs Ive seen are self powered.polkaudio sound quality competitor since 2005
SVS and Adire make passive subs.
HSU use to, not sure if they still do.
Alot of the times it is just easier to buy a powered sub, because with a passive sub you STILL need a crossover - and preferably one with a phase knob, volume, and crossover.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
It's great to have a valuable member like Sid around, otherwise we might forget how crappy Polk is and how great Def Tech is.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
When did I say Polk was crappy?
I dont like the RTi line and their subwoofers.
And if you think I am telling you DT subs are better than Polks, your off - again. In the price range, both of their subs cant hit below 20hz, much less 25hz.
And I am very glad you find me valuable. I was getting worried.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
