Behringer Feedback Destroyer / Any Users?
pearsall001
pearsall001 Posts: 5,290
Anyone used the Behringer Destroyer PRO FBQ2496 in their system? What did you think of it, did it improve the bass response enough to warrant it's purchase? Thanks & Merry Christmas!!
Post edited by pearsall001 on
  • opus
    opus Posts: 1,252
    edited December 2005
    Hey 001, Merry Christmas to you also.
    I have a BFD and am very happy with the results. I bought mine used here on the forum so the price was right :). Mine tamed some very nasty peaks in my room and I enjoy the "new sound" from my sub. Others here aren't believers so take this for what its worth. Plus you get to spend alot of geek time graphing and such :p
    kevin
    The Flea rig
    Hitachi 50VG825 LCD
    Rotel RSP 1066 (pre) :)-flea market
    B&K St-202 (mains)-flea market
    Carver M 200t (x2) (center and surrounds)-flea market
    Blu-Ray..PS3 (dvd player)
    Polk RTA-11t-flea market
    LsiC, Fxi30's
    Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
    -flea market
    AudioAlchemy DDE v1.0 DAC-flea market
    Cambridge Audio Azur 640 CDP-flea market
    Signal Cable and Kimber Kable
  • Early B.
    Early B. Posts: 7,900
    Cool. How can I determine if a BFD will be beneficial for my particular situation or should I assume that nearly everyone could benefit?
    "God grooves with tubes."
  • gatemplin
    gatemplin Posts: 1,595
    You can only benefit from the BFD if you have peaks in the frequency response that you want to cut, or if you want to change the response curve by adding something like a house curve.
    I use the BFD 1124DSP not the pro.
    Graham
  • McLoki
    McLoki Posts: 5,231
    Get a radio shack meter and plot your bass curve with just your sub. If you look at it and see some peaks you would like to tame, give the BFD a shot. I love mine and it was well worth my purchase price.
    Michael
