Behringer Feedback Destroyer / Any Users?
pearsall001
Anyone used the Behringer Destroyer PRO FBQ2496 in their system? What did you think of it, did it improve the bass response enough to warrant it's purchase? Thanks & Merry Christmas!!
Post edited by pearsall001 on
Hey 001, Merry Christmas to you also.
I have a BFD and am very happy with the results. I bought mine used here on the forum so the price was right
. Mine tamed some very nasty peaks in my room and I enjoy the "new sound" from my sub. Others here aren't believers so take this for what its worth. Plus you get to spend alot of geek time graphing and such
kevinThe Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre)
-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable -
Cool. How can I determine if a BFD will be beneficial for my particular situation or should I assume that nearly everyone could benefit?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
You can only benefit from the BFD if you have peaks in the frequency response that you want to cut, or if you want to change the response curve by adding something like a house curve.
I use the BFD 1124DSP not the pro.Graham -
Get a radio shack meter and plot your bass curve with just your sub. If you look at it and see some peaks you would like to tame, give the BFD a shot. I love mine and it was well worth my purchase price.Early B. wrote:Cool. How can I determine if a BFD will be beneficial for my particular situation or should I assume that nearly everyone could benefit?
