SVS people... need your opinion.
StopherJJ1980
StopherJJ1980 Posts: 267
edited December 2005 in Speakers
Im looking at getting an SVS sub for my setup. First let me say it takes a LOT for me to have faith enough to purchase something without testing it out first but I usually have found nothing but raves and praise for these subs. I just wish there was SOMEWHERE that offered sound demos, but oh well... anyways...
I have a fairly large room, a little over 4000ft3, 20x20 w high ceilings. I am ona budget, esp after replacing my olf R series with the RTi. So I was debating getting a PB-10isd with the option to get another later if needed, or should I save a bit and go for a pb12 or dare i say a pb12-isd2?
Right now I have an old cerwin vega 10" that actually hasnt been that bad and does ok for now. For me a nice smooth response down to 20Hz and musicality is more important than sheer SPL, quality over quantity :) So anyone have experience with these subs in largish rooms? Any suggestions?
-Stopher
Tempe, AZ
Setup:
Polk RTi8 Mains
Polk CSi5 Center
Polk FXi3's Surround
Cerwin Vega HTS10 Subwoofer
Yamaha HTR-5740 AVR
Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR
Post edited by StopherJJ1980 on
  • Early B.
    Early B. Posts: 7,900
    Be patient. Save your money and buy the biggest, baddest sub possible. With the room size you've got, you're gonna need it.
    "God grooves with tubes."
  • wingnut4772
    wingnut4772 Posts: 7,519
    What kind of budget are you looking at?
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • dorokusai
    dorokusai Posts: 25,576
    AMEN!
  • Airplay355
    Airplay355 Posts: 4,298
    Save and get the big **** one. Getting a smaller one will just make you want to upgrade again. Buy what you'd really want now. No sense in buying something if you'd rather have something else.
    SCompRacer Posts: 9,121
    I agree with the save and buy once suggestions. Contact SVS and see what they suggest for your room.
  • Ron Temple
    Ron Temple Posts: 3,212
    Most output south of the PB12+/2 is the cylinder 25-31+...
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
