DVD progressive scan
Willow wrote:Thanks Steve, looks like I will have to buy one and return it if I don't see a diff. No one I know has a Pscan.
I am talking Pscan
Willow
You will see a difference, my DVD player lets me go Progressive or Interlaced, not exactly sure why, but it definitely is more grainy when I switch to Interlaced...
Entry Prog Players are really inexpensive nowadays.
Get yourself a DVDO Iscan and hook it up to that VCR I sent you. You'll get a scaled progressive feed...
Scott -
thehaens@cox.ne wrote:my DVD player lets me go Progressive or Interlaced
So does mine. There's a button on the face to turn the PScan on and off."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
ND13 wrote:So does mine. There's a button on the face to turn the PScan on and off.
Well I didn't think mine was the only one
, just really don't know why they would even have such an option.
Maybe for those that are still using standard RCA's or S-Video I guess. -
thehaens@cox.ne wrote:Well I didn't think mine was the only one
I didn't mean anything by my reply, just that I was thinking the same thing is all."SOME PEOPLE CALL ME MAURICE,
60h * (720 * 480) / ( 1920 * 1080) = 10hND13 wrote:Yes it does take 480p and the Motorola cable HD box sends 1080i. It also has a 120gb HD hard drive which, in standard resolution, is good for 60 hours...not sure how many in HD mode.
Not sure how much the compression changes between the two so it might not be an accurate estimate at all...
I think mine is advertised 60h SD, 20h HD...
That reminds me- with TWC in Raleigh & a Sci ATL 8300 DVR box, if you take the remote and hit 9999 it'll go into the service menu & you can get lotsa info- Including hard drive space and est recording time left.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
thehaens@cox.ne wrote:Willow
Scott
I saw that DVDO seems like a great thing, the down side is the price...couple of Gs
