DVD progressive scan
Willow
I might be the only one on the forum with a non-progressive scan DVD player.
I have the Marantz dv4200. Nice player.
I have an LCD tv and wondering if I would and could benefit from a Pscan player?
What would I notice?
thanks
thanks
Post edited by Willow on
As long as your LCD accepts PScan input, you might want a Pscan player. progressive scan images are more fluid, film-like, smoother.
Do a Yahoo search on "what is progressive scan" to get all the details about the technology and it's benefits...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Deponds on if the TV or the player does a better job of making it progressive. Is the native resolution of your LCD 768p?
steveinaz wrote:As long as your LCD accepts PScan input, you might want a Pscan player. progressive scan images are more fluid, film-like, smoother.
My TV indicates "yes" to PScan. -
PolkThug wrote:Deponds on if the TV or the player does a better job of making it progressive. Is the native resolution of your LCD 768p?
I am not sure, it indicates 1366X768. From what I put together the answer would be yes.? -
P-scan really doesn't get you much on a nice TV... I'd stick with your DVD player & let the TV handle the deinterlacingGallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Thanks I just wanted to be sure I wasn't missing out on anything.
Are we talking "upscaling" or Progressive scanning? I'm a little confused...
Willow, if your LCD supports it, try borrowing a friends PScan player and see if the increased quality is worth the upgrade cost...chances are you'll like Progressive scanning better.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
unc2701 wrote:P-scan really doesn't get you much on a nice TV... I'd stick with your DVD player & let the TV handle the deinterlacing
huh?
The TV cannot change an interlaced signal into a non-interlaced (progressive scan) signal, it's got to come from the source (DVD Player). If the DVD Player is not PScan, your TV is displaying interlaced images...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Thanks Steve, looks like I will have to buy one and return it if I don't see a diff. No one I know has a Pscan.
I am talking Pscan -
steveinaz wrote:Are we talking "upscaling" or Progressive scanning? I'm a little confused...
Steve, his TV already converts the picture to progressive (and upscales it too). The PQ will only improve if the deinterlacer in the DVD player is > the deinterlacer that is already in his TV.
His LCD TV has a native resolution of 768p, meaning a 480i source will be deinterlaced and upscaled to his native resolution. -
I thought his player was not progressive scan? You can hook up a non-progressive scan DVD to a television that can handle progressive scan and the TV will convert the signal to PScan??
I know you can either use your DVDP or your TV to upscale (provided they support it) but I've never heard of converting a non-Pscan signal from a DVD.
Man I AM lost.....Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
PolkThug wrote:Steve, his TV already converts the picture to progressive (and upscales it too). The PQ will only improve if the deinterlacer in the DVD player is > the deinterlacer that is already in his TV.
Even if when I watch a dvd it shows on my screen 480I ? -
steveinaz wrote:I thought his player was not progressive scan?
Don't worry I'm a lil lost .... -
steveinaz wrote:You can hook up a non-progressive scan DVD to a television that can handle progressive scan and the TV will convert the signal to PScan??
If the TV has a native resolution that is progressive (540p, 768p, etc), YES. Deinterlacers are not limited to dvd players. -
Willow wrote:Even if when I watch a dvd it shows on my screen 480I ?
It is displaying the input signal. What model of TV do you have? -
Now I'M confused. Is the signal on a DVD inherently "interlaced"? I would assume not, so if you h ave a progressive scan DVD player, it sends the "full" signal to the TV, which then just draws it. OTherwise the DVD player is essentially sending half the signal, which the TV just has to ... make up on the fly, via line doubling or whatever system they use. I see an inherent difference here...If you will it, dude, it is no dream.
PolkThug wrote:It is displaying the input signal. What model of TV do you have?
LG32LZ50 -
Willow wrote:LG32LZ50
lmao! I believe you have a built-in Faroudja deinterlacer in that model of LG (this is a good thing). Keep the Marantz, you've got a good combo already!! -
PolkThug wrote:lmao! I believe you have a built-in Faroudja deinterlacer in that model of LG (this is a good thing). Keep the Marantz, you've got a good combo already!!
Ok Now to add another twist, mine was the model without the chip, I was discussing this in another thread a while back asking if I should return mine for the one with the DCDI.
So now what does this mean? -
Willow wrote:Ok Now to add another twist, mine was the model without the chip, I was discussing this in another thread a while back asking if I should return mine for the one with the DCDI.
doh! This means that you may benefit from Denon or another nice DVD player but may not benefit from a DVD player that you will find at CC. -
DVD's are inherently interlaced. If you've got a quality TV, no need to drop cash on a p-scan player, especially if you really like the one you've got.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
PolkThug wrote:doh! This means that you may benefit from Denon or another nice DVD player but may not benefit from a DVD player that you will find at CC.
I was thinking the pioneer elite or the denon -
I'll be a monkey's uncle.
So I can connect my stone-aged non-progressive scan DVD, via super-video cable to a high tech HD TV and the TV will convert the image to non-interlaced? Holy Crapoli.
Learn something new everyday...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
steveinaz wrote:I'll be a monkey's uncle.
You and me both -
yep. Now the progressive DVD player has one advantage: it can do the conversion in digital domain. However, the variability in execution is so large, that if you're happy with your player and you've got a good tv, then there's no need to go out and buy a progressive player. I'll try to find you a link.
...here we are:
http://www.hometheaterhifi.com/volume_7_4/dvd-benchmark-part-5-progressive-10-2000.htmlGallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Cool, thanks. To quote Jack Nicholson in "A Few Good Men"..."don't I feel like an ****."Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
PT,
I've got a Philips 30" WS HDTV, which I believe is native 1080i, right? I just had my cable company come out and bring me my new HD/DVR box. Since my TV is an older model it has only one HD input, component or RGB. I had to hook up the receiver to the HD input via components. If I were to go out and get a HDMI to RGB cable(if there is such a thing) and hook it up that way, can I then rehook up my Pscan DVD player via the components or does it even really matter since you say that my TV will do the work for me??"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
There's no HDMI-RGB. Just HDMI to DVI and your DVI input has to be HDCP capable. Which HD box to you have? a bunch of them allow you to plug your DVD player into the HD box. When the box is turned off it passes the DVD signal. (or you can just get an AVR w/ component switching)Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Not sure on that Philips, some 1080i tube HDTV's won't take a 480p signal.
On your HD STB, in its setup menu, can you make the output be 1080i via component?
(and yes it is the most confusing time in all of history to buy a TV) -
Yes it does take 480p and the Motorola cable HD box sends 1080i. It also has a 120gb HD hard drive which, in standard resolution, is good for 60 hours...not sure how many in HD mode.
When the DVD was hooked up there the screen displayed 480p input and now with the HD converter hooked up the same channel displays 1080i input."SOME PEOPLE CALL ME MAURICE,
