Bad deal from futur shop!
rumby
rumby Posts: 2
edited December 2005 in Speakers
Hi! I bought a package deal from Futurshop that goes like this.
2 rti10
1 csi3
2 fxi3
1 psw10
And I bought a Yamaha rx-v 2500
I don't think these speakers will fit well together for home theater; everything seem's too weak for the rti10. :confused:
  • BjornB17
    BjornB17 Posts: 752
    looks like they just threw random speakers in there.
    KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
  • cmy330go
    cmy330go Posts: 2,341
    At least they got the main speakers timbre matched. However a CSi5 would be a much better option, and I would REALLY recommend a subwoofer upgrade. The surrounds aren't really a bad choice. But if it were me I would want the FXi5s just because.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • rumby
    rumby Posts: 2
    Thanks for the advice, I'll try to return the sub and upgrade if the will let me. :)
