Static when not in 5.1
trevlix
Hello all!
Let me start by saying I'm a really big newbie in regards to stereos and 5.1, etc. I have a KLH R-5100 receiver and just bought the Polk RM6800 speakers. They sound amazing!
However, whenever I'm not playing something which is 5.1 surround, I get a static noise coming out of all speakers. This is especially noticable when I am watching my satellite which, even though it is hooked up with digital coax, is only in stereo mode. The static seems to disappear in 5.1 mode with a true 5.1 thing playing (like a DVD). If I put 5.1 mode on with the satellite, I still get the static.
The static is noticable at low volumes, but it is somewhat annoying. Does anyone know what i can do for this? I'm beginning the think its the receiver, but I'm not totally sure. Thanks!
Tyler
Tyler
Post edited by trevlix on
The receiver would be my first guess - is an upgrade an option for you?
Or do you have a friend or co-worker that you could try out their AVR in your home for a day and see if that clears it up? You could also try and purchase one from a place with a liberal return policy (if it doesn't fix the issue). You could also try and call or e-mail tech support for your AVR. I don't think the problem is a speaker issue.Polkmaniac wrote:The receiver would be my first guess - is an upgrade an option for you?
Just trying to give you a few options to narrow down the problem. good luck with it.
Thanks all. I can't afford to buy a new receiver now but a friend has one I'm going to borrow and test out. I'll let everyone know what I find out.
