Second SVS
beardog03
beardog03 Posts: 5,550
I was thinking of getting another SVS sub...
I can`t really afford the one(s) I really want right now, so I was thinking of getting a CS cylinder and either running it off of the other PC-Ultra, or maybe one of the Rotels (bridged) that I haven`t sold yet...
Waddaya think..?
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
Post edited by beardog03 on
  • Schris22
    Schris22 Posts: 983
    edited December 2005
    just from what I've heard in history...if you really want it and can't afford it now....but perhaps "soon" (subjective I know), then just wait and get what you really want then having to replace what you are about to get.
    Chris
    Receiver: Onkyo TX-SR502-S
    DVD Player: Pioneer DV-578A-S
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
    Subwoofer: 10'' Dayton 100 Watt
  • lanion
    lanion Posts: 843
    I think you are insane.
    My Iron Man training/charity blog.
    HT:
    32" Sharp LCD. H/K dpr 1001 to Outlaw Audio 7900 to Polk LSi + Paradigm Studio center. Hsu DualDrive ULS-15. PS3/Wii. Outlaw 7900.
  • beardog03
    I was just wondering if the plus driver and the ultra driver would blend very well..
    looking back at my history, you may find that saving money is not one of my forte`s..!!!!
    I really want the four driver ultra..!!
    no way I can save up for that anytime soon, as I am still on my quest for my Cary :rolleyes:
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • beardog03
    you are correct sir..!!
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
    VR3 Posts: 29,700
    Dont mix the Ultra and +...
    Dosnt really matter if it blends or not... its just a different driver...
    You wouldnt mix the RTi series with the LSi would ya?
  • Dr. Spec
    Dr. Spec Posts: 3,780
    While dual Ultra would be ideal, the most important thing is to buy the same size/tune cylinder, since the phase response will be very similar in the 20-39PCi, 20-39PC+, and PCU models. That way you will get reinforcement at all frequencies with the minimum potential for cancellation.
    SVS
  • wingnut4772
    wingnut4772 Posts: 7,519
    I just decided to experiment last night and I set up my PC Plus 20-31 with my new PB12 Ultra/2. It smoothed out a little dip in the room some and I think it sounds a bit more integrated. My room is narrow so I have wicked placement restrictions. The Ultra is where the Plus used to be and I placed the plus to the left of the sofa. It sounds pretty decent. I have to say also though that the PB12 by itself sounds incredible and if I wasn't running around with a test cd and an SPL meter lke an obsessive maniac that would be enough.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • opus
    opus Posts: 1,252
    Dr. Spec, Am I correct in reading that if a person had two 25-31 pc+ and wanted to run them tuned different, say 1 at 25hz and another at 16hz, that this would be bad. I'm also insane and always thought that someday I would slam another pc+ in the room just for kicks.
    The Flea rig
    Hitachi 50VG825 LCD
    Rotel RSP 1066 (pre) :)-flea market
    B&K St-202 (mains)-flea market
    Carver M 200t (x2) (center and surrounds)-flea market
    Blu-Ray..PS3 (dvd player)
    Polk RTA-11t-flea market
    LsiC, Fxi30's
    Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
    Behringer Feedback Destroyer
    -flea market
    AudioAlchemy DDE v1.0 DAC-flea market
    Cambridge Audio Azur 640 CDP-flea market
    Signal Cable and Kimber Kable
  • BIZILL
    BIZILL Posts: 5,432
    i cannot scientifically tell you why, but it wouldn't make sense to me to do so. just set 'em both at 20 hz. having dual subs in that config would seemingly yield higher spl's in both 16hz and 25hz and actually all other frequencies. but what do i know?
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • beardog03
    Sid,
    you have a piont there...
    Dr. Spec,
    Thank you,
    use same size tubes and tuning characteristics to minimize cancelation...got it..!!
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • Early B.
    Early B. Posts: 7,900
    Do it, Bear, do it. Sell the Rotel to help fund the purchase, whatever it is.
    Someday I'll have two, too.
    "God grooves with tubes."
  • beardog03
    I`m thinkin PC-Ultra # Dos
    I still need to get the Cary first, but I was cruzin the SVS site (thanks wingnut !) an dstarted thinking about a box sub with two ultra`s in it..
    But as DR. Spec pointed out, I should stick with another PC-Ultra..!!
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • wingnut4772
    I have the Ultra tuned at 16 and the Pc is just at its natural 20 and it sounds good to me. If we are not supposed to do that I guess ignorance is bliss. My SPL readings improved too so I don't know what to say.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • opus
    opus Posts: 1,252
    [QUOTE= if I wasn't running around with a test cd and an SPL meter lke an obsessive maniac that would be enough.[/QUOTE]
    Hey Wing, How about sharing a graph with us, if you are truly obsessive that is. Several people have posted their SPL graphs over the months and they are interesting to look at. :cool:
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • wingnut4772
    Do you know where I would get a graph program? I don't have Excel. I just did a little hand drawn dealie.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • opus
    opus Posts: 1,252
    Shoot me a pm with your non-corrected spl numbers and hz levels and I will make you a computer drawn dealie ;)
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • BIZILL
    BIZILL Posts: 5,432
    i just love "dealies"!!!
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • wingnut4772
    Thanks Opus. Let me find my sheets here somewhere. They're in a notebook type dealie :D
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Dr. Spec
    That is correct. It's not the frequency response so much as the phase response. Unless the phase response is the same for each subwoofer, you can get cancellation at certain frequencies. And since the phase response changes pretty drastically when you alter the tune, both subs should always be run at the same tune point.
    SVS
  • wingnut4772
    Opus, PM sent. Thanks :)
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • opus
    opus Posts: 1,252
    Wingnut, With a little help from Mcloki here are the numbers you sent.
    These are corrected and graphed thanks to snapbug.
    I am a little confused on which sub this is or if it is both. Let us know. :)
    bob.JPG 50.3K
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • wingnut4772
    This is actually the reading from the PB12 Ultra/2 by itself. I have my system set at a crossover of 60? The corrected numbers look a little better, but I still have dippage.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • jdhdiggs
    jdhdiggs Posts: 4,305
    Penicillen should clear that up for you....
    Actually, try raising the X-over on the SVS a bit and focus on the dip. It may be a phase issue, level matching, or maybe the room. Moving the X-over should help isolate the issue.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • wingnut4772
    I have the crossver on the actual SVS disabled as my pre/pro handles that. Do you mean to activate it or to raise the pre /pro crossover setting. I took readings while turning the phase knob on the Ultra and I have it where the SPL was highest...and I am allergic to penicillin :D
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • dkg999
    dkg999 Posts: 5,647
    Dr. Spec - your comments on the phasing of two different subs is interesting. I run an SVS 20-39 PC+ in the front left corner, and an SVS PB10 in the right rear corner of my HT room. I am in an apt. so getting good bass effect without annoying the neighbors is critical. I have found two things with having the dual subs that are of different types. 1) I can fill the room with bass at relatively low SPL's. 2) By adjusting the phase controls I can minimize the bass that starts shaking an rattling things. On #2, an EQ might do the same thing, however by tweaking the phase controls I have been able to accomplish the same thing good enough for an HT in an apt.
    DKG999
  • jdhdiggs
    I would suggest moving it higher on the pre/pro and see if the dip moves.
  • wingnut4772
    No. Dip ain't moving. I am doing another furniture re-arranging and I am going to try and fit it up in the right corner to see.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
