my marantz only has one set of "multi channel inputs...
the new sacd and dvd that i just both have 5.1 hookups, can i hook up both with a "Y" splitter in to the one set of inputs on the marantz sr18ex???
--MARANTZ SR18ex 140wpc x 5 (high current/direct amp)thx-ex "ultra"
electrohome tube amp 15watt. pr channel(aprox.1955a.d.) for 2 channel audio{recently recapped& tubed-5ar4power rect. & 12au7)
-kenwood amp(km-996/140wpc(used for 7.1 rears(thx ex)
-toshiba dvd video/audio player(progressive scan) sd-4700
-sony sacd cd player scd-xe670
-nakamichi "music bank cd player "6+1disk(20bit dac)
-toshiba hifi vcr (v3 pro head)
-motorola digital cable box
-RCA 32' "home theater" PIP tv
-polk RT800i x 2 (mains) ~bi-wired
-polk sc400i x 1 (center) ~bi-wired
-polk fx300i x 2 (side fx) ~di-pole
-polk r10 x 2 (rears)
-polk pws250 (powered sub)
-2x173ltr(48"-16")sono subs(powered by kenwood kr-7200 250watt & w/ audiosource EQ (model eq eight/series II)
-Thorens td-166 mk II/Grado silver fs1
-Thorens td-160/empire 66cart
-Dual 601
-D.I.Y. carfea "little big horns"-(pioneer full range 8" & fostex 4" compression horn tweaters
-sony (ps1)
-sony (ps2)
-haroo, "GOD gave you the gift of sound, Your gift to God is what you do with it!"
"marantz haroo"
-Dual 601
-sony (ps1)
-sony (ps2)
"marantz haroo"
Post edited by haroo on
Dig-Coax, or the Fiber Optic?
I would be inclined to think that a high-quality "Y" cable would work, but it wouldn't be ideal. Depending on the output impedence of the players and how they behave when they're off----you might get some sort of interference--- or it might not work at all. It would be worth a shot. Some sort of switching device would be the best way to go, but again, I'm not sure where you would find one. Perhaps someone on here will know.
Jason
Testing
Testing
I'm holding out on this whole DVD-Audio SA-CD thing for a bit untill I figure out what is gonna be worth it...<I'm still bitter about the DAT and MD thing>
I do have a few DVD audio discs, and I enjoy all of them in 5.1 separation through my nice little fibre-optic cable, but that is because the producers of the disc were kind enough to add a 5.1 track to the DVD.
Not all dvd-audios are like this, but most are.
Is it the super high res that dvd-audio is... no but I can wait.
cgravil: I'm still sober and I too didn't realize that it was a DVDA. You were right on the money. Whenever I consider a CD purchase I consider DVDA (DVD playback), but no luck. Glad to hear you're jammin' the ghe...5.1 audio:D
