Ok i got a computer question, my laptop
faster100
faster100 Posts: 6,124
edited April 2024 in Clubhouse Archives
Ive been building computers for several years but never fooled with laptops.. I have a new compaq m2000 notebook.. and it has a dvd player/cdr combo drive... I want a dvd burner in it.. after the newegg link for burners i seen they had a nec universal i guess dvd burner for laptops.. all the reviews said it fit like from dell to compaq to others.... anyone know if this is like a universal type thing in new laptops... they all basically fit the same?
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
  • cmy330go
    cmy330go Posts: 2,341
    edited December 2005
    I've done a bunch of searching for an answer on this. I would like to upgrade the burner in my Compaq 2585, but I can't seem to find a compatability list anywhere. I finally gave up and sent an e-mail to NEC :confused: . If I hear anthing back I'll let you know.
    Dave
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • faster100
    ok cool, in the mean time i'll call newegg.com
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • polksda
    polksda Posts: 716
    Most laptops/notebooks use proprietary optical drives. Not proprietary with respect to the types of connections, but proprietary as to the bay and slot size and the bevel.
    Hard drives are different; usually just about any 2.5 inch drive is ok, since you mount it to a bracket anyway. That's one of the biggest improvements you can make to a laptop's performance: take out the (usually) 4200RPM drive and replace it with a 7200RPM drive. Huge increase in performance, although your battery life will suffer a little bit.
  • Mike682
    Mike682 Posts: 2,074
    faster,
    I have the compaq m2007 with the same drive. I'm not sure what dvd burner would fit but I would recommend using the live chat feature in HP TotalCare. Tell 'em what you want and they should be able to give you the part number for the dvd burner.
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
