Ok i got a computer question, my laptop
faster100
Ive been building computers for several years but never fooled with laptops.. I have a new compaq m2000 notebook.. and it has a dvd player/cdr combo drive... I want a dvd burner in it.. after the newegg link for burners i seen they had a nec universal i guess dvd burner for laptops.. all the reviews said it fit like from dell to compaq to others.... anyone know if this is like a universal type thing in new laptops... they all basically fit the same?
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
I've done a bunch of searching for an answer on this. I would like to upgrade the burner in my Compaq 2585, but I can't seem to find a compatability list anywhere. I finally gave up and sent an e-mail to NEC
. If I hear anthing back I'll let you know.
DaveHT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
ok cool, in the mean time i'll call newegg.comMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Most laptops/notebooks use proprietary optical drives. Not proprietary with respect to the types of connections, but proprietary as to the bay and slot size and the bevel.
Hard drives are different; usually just about any 2.5 inch drive is ok, since you mount it to a bracket anyway. That's one of the biggest improvements you can make to a laptop's performance: take out the (usually) 4200RPM drive and replace it with a 7200RPM drive. Huge increase in performance, although your battery life will suffer a little bit. -
faster,
I have the compaq m2007 with the same drive. I'm not sure what dvd burner would fit but I would recommend using the live chat feature in HP TotalCare. Tell 'em what you want and they should be able to give you the part number for the dvd burner.Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29
