SRS Distance From wall?
Ricardo
I finally moved the big boys away from the TV area; have them "temporally" in another location, same wall; they are now about 4 inches from the wall and the lows REALLY improved.
Is there like a standard recommended distance from the wall? What do you SRS owners have?
SOPA
SOPA
Post edited by Ricardo on
I say play with the distance until you get the desired effect. As you know, I keep mine 8" from the back wall."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
It says 5". Remember its a guideline. For me there is a fine line between increasing the bass for the sake of it and what was intended by the artist/recorder.
RT1 -
My 1.2TL's are about 12" off now, but I will probably move them back a bit. I put some Dayton spikes on the feet. Another option is to anchor the speakers to the wall stud. There is actually a screw in the back that can be removed to put a brace in place. Polk does not recommend using both the spikes and the brace.Speakers: Polk 1.2TL w/VR3 mods and Dreadnaught interconnects
Amplification: ARC Reference 110 w/KT150s; Cary Audio SLP-05 w/Ultimate Upgrade
Vinyl: VPI HW19 MK III (Heavily Modded); Origin Live Silver Tonearm; Hana ML Cart; Pete Riggle VTAF; VPI TNT Platter; SAMA; Iphono3
Digital: Aurender N100H; Benchmark DAC1 -
I also moved mine away from the wall recently.. and the bass did improve some.. they are now about 6" from the back wall. the soundstage is a little better too. Don't know how that could be possible. but the bass is better now.PolkFest 2012, who's going>?
5.13845 inchesHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
