WTB: External Amplifier
shawn474
Looking to power up my home theater system with an external amplifier in the $200.00 range. Not sure what that can get as I am a novice so any advice is appreciated (2 channel, etc). I have the Polk RM6005 speaker package and a powered infinity bu-2 sub. Sounds good (I understand I am on the low end of the totem pole in here!), but I feel like it could be cleaner with an amp. Any advice and anyone who has an amp in this price range is appreciated. Thanks again for all replies.
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
Front: Polk LsiM703
Rear: LSI fx
Post edited by shawn474 on
What type of receiver are you using at the moment?
Receiver: Yamaha RXV595
After some contact from forum members, it has come to my attention that I should probably upgrade my receiver as well. Therefore, anyone with a 5.1 or 7.1 receiver with external amp please let me know. I am willing to spend in the 400.00 dollar range for the package. Sorry to be a pain, but without all this feedback, I would have probably just bought the first thing that came across. THANKS VERY MUCH!Shawn
Front: Polk LsiM703
Rear: LSI fx
DVD Player: Sony PS4 -
Beardog has a Rotel RB980BX, send him a PM.Political Correctness'.........defined
President of Club Polk -
shawn474 wrote:Therefore, anyone with a 5.1 or 7.1 receiver with external amp please let me know. I am willing to spend in the 400.00 dollar range for the package.
Do you mean a receiver with pre-outs?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
http://www.ubid.com/actn/opn/getpage.asp?AuctionId=10546569
This is a decent amp for around $300.00 and you can add it to your avr and you wiil not be dissapointed. Lou
My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
anonymouse wrote:I think he means a receiver and an amp for $400.
Seriously?
Well, with that budget don't worry about separate amplification. Consider just getting a nice receiver for now.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Be sure your receiver has preouts. or else you'll be buying an amplifier for nothing
I don't know why you would be so pessimistic early b...There are always lots of nice amps here for around $200, and there are lots of perfectly fine receivers (yamaha, denons or hks) that are 4 or 5 years old that are also less than $200 and would do a respectable job as a pre-pro.
Shawn, if you're happy with the sound of your yamaha and are comfortable with its features, just try to find one of the models up the line such as the 795, 795a, or 995. All of them had pre outs and go for far less than $200 on the used market. Then ditch the 595. You can probably make this swap with a $100 outlay which leaves you up to $300 for an amp. -
jawhog wrote:I don't know why you would be so pessimistic early b...There are always lots of nice amps here for around $200, and there are lots of perfectly fine receivers (yamaha, denons or hks) that are 4 or 5 years old that are also less than $200 and would do a respectable job as a pre-pro.
Just trying to save him from upgraditis.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
