Couple of cable questions
jcaut
jcaut Posts: 1,849
Is there a rule of thumb as to how far you can run a composite video signal? How about S-video? Thanks for the info.
And okiepolkie, I replied to your PM and also asked a couple of questions, if you get a chance to read them.
Jason
Post edited by jcaut on
  • mantis
    mantis Posts: 17,374
    edited November 2005
    Composite cideo can run over a rg6 75 ohm cable about 500 feet. S video , depending on design or adapters can be pushed a few hundred feet.
    Dan
    Dan
  • jcaut
    jcaut Posts: 1,849
    Thanks for the reply, Dan. The lengths I'm working with are less than 50ft., so I guess either one should work. I may just go with the composite, since I've got plenty of RG-6 available to me and the application doesn't require exceptional quality anyway.
    Jason
  • Willow
    Willow Posts: 11,231
    edited December 2005
    Keep in mind that composite is of lesser quality than Svideo
