??? about hooking up to New big screen.
Nighthawk
Nighthawk Posts: 3
Just purchased a 62" big screen and todasy bought a pr of R30 speackers. I also got speaker wire ( two wires going into one plug).
Will this wire work or do I need to do something different.
thks ron
Post edited by Nighthawk on
  • michael_w
    michael_w Posts: 2,813
    edited November 2005
    Do you have a seperate receiver? This wire just goes from two wires into a single rca plug right?
  • Nighthawk
    Nighthawk Posts: 3
    Don't have a sperate rec and 2 wires into a single plug.
    thks ron
  • michael_w
    Well ron, the R30's are going to need a little more power than the line level output you tv is putting out... It would be like hooking them up to the headphone jack of a portable cd player. It might work for small, efficient headphones but you need something in between to amplify the signal.
    What you need is a receiver, integrated amplifier, or a pre/pro amp and an amplifier. The speaker wire you have now won't really work. It all depends on your setup as to what cables you will need.
