CD Player Choices? Rotel? Cambridge Audio? Denon?
Good Luck William, I will be interested in hearing your review. I a really beginning to question those CDP companies that try to cover the gamut between low cost and high-end. You probably have engineers on one hand who want to do the right thing and bean counters on another trying to squeeze every last buck out of a unit. Generalized a bit here, but I am beginning to lean towards those companies who focus on only building quality sources. I see the 640 getting some good reviews, but like you say what good is it even if it sounds good if it wont handle a store bought CD. Well maybe you'll have better luck.
RT1 -
Yeah reeltrouble 1, actually i have enough gear around here to open up a used audio shop. i heard good things about the Cambridge Audio CD players and i wanted a new toy to mess with while my Symphonic Line Vibrato CD player is getting factory upgraded with the new MK II 24 bit mods.if the 640 C is a disapointment i will probably never mess with Audio Advisor or any more inexpensive mass market gear again.thanks....WCW IIIreeltrouble1 wrote:Good Luck William, I will be interested in hearing your review. I a really beginning to question those CDP companies that try to cover the gamut between low cost and high-end. You probably have engineers on one hand who want to do the right thing and bean counters on another trying to squeeze every last buck out of a unit. Generalized a bit here, but I am beginning to lean towards those companies who focus on only building quality sources. I see the 640 getting some good reviews, but like you say what good is it even if it sounds good if it wont handle a store bought CD. Well maybe you'll have better luck.
RT1Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.
WCW,
I dont necessarily think of Cambridge as mass market, but suppose it could be thought of that way. But as your experience with the Cambridge lower end unit was not a good one, I wonder about the build of the 640. My two major goals for 06 are to improve my source and pre in the 2ch rig. I thought I had a something working on a MF tri-vista but that seems to have fizzled.
Anyway, will look for your impressions of the 640 and the upgraded Symphonic upon its return to you.
RT1 -
the bad part is that the D500 SE was the best player that Cambridge Audio built prior to the release the newer improved Azur series. i bought a demo unit and some others on this forum either own or have owned the D500 SE without encountering the problem that the one that i bought developed so who knows ?the Cambridge 640c uses the same Wolfson 24 bit DAC as the Arcam CD 73 T and is supposed to sound very good for the money so i will just keep my fingers crossed.the Symphonic Line CDP is a $5000,00 player and sounds organic like a good turntable does. i am getting it modded because they came out with the MK 2 version this year and i want to keep it up to date. i will let you know how the 640c sounds after i let it settle in for a week or so after i get it. thanks....WCW IIIreeltrouble1 wrote:WCW,
RT1
Still like my Jolida. Overall build quality is very good. If there is a negative point I'd say only the transport is a bit 'plastic' compaired to the rest of the heavy aluminum face and 3lbs remote. It does what it needs to do but it seem odd to have such a HD remote and such a light weight CD loading tray. Oh yea it has tubes too
Sound wise it keeps getting better. Many cd's I'd given up as junk are now very listenable.
