Getting with the times
  • Willow
    Willow Posts: 11,255
    edited November 2005
    Ok got the kit the other night. I hook it all up and nothing works. @ reasons, they have not connected me at the box and or my home security system doesn't have a filter. I called the alarm company they can have someone come over free of charge but the filter for the alarm since they use a different size of cable I must pay 65$. GRRRRRRRRRR
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    Your alarm system uses RJ-45??
  • Willow
    I don't know, it looks like a reg phone cable but the end is much bigger.
    What does using that cable mean?
  • BlueMDPicker
    It's just odd to me -- but, I'm no alarm expert.
    I've had several homes with alarms and they used RJ-11 (single line) or RJ-14 (two line), which are the same physical size, connections from the alarm control panel to the phone jack. An RJ-45 can be used for a multi-line (more than two) phone system or ethernet connections (you probably got a cable with RJ-45 terminations in your kit to go from modem to computer) and has a distinctively rectangular end profile.
    Perhaps the alarm system is networked to a main control panel in your building complex? Anyway, sounds like a "GOTCHA!" by the phone company. I've never seen an RJ-45 DSL blocker, but they must have such a thing.
  • Willow
    My phone company and all our jacks are good they sent us several filters for those. The alarm box has that RJ-45. So I think it's the alarm company "Gotcha" scam. Any hoot I dont want to return the DSL for cable, I'd rather pay 65$.
  • dorokusai
    dorokusai Posts: 25,576
    My winter project is too replace all my phone wiring with CAT5 and upgrade the wall plates at the same time. I may also build in some future expansion with A/V but that will be room dependent.
  • Willow
    So I am all hooked up, I copied a couple movies and CDs. I am about to burn another CD, I put the blank in the drive I hear this mini crunch sound. Now my burner can't even read a regular cd or dvd. GRRRRRRRR. Off to exchange this puppy tomorrow.
  • audiobliss
    audiobliss Posts: 12,518
    bandwidthoplace said my connection is 4.7 megabits per second, storage is 577.9 kilobytes per second, and the subjective rating is awesome!, lol.
    McAfee said my speed is 556.32kbps which is 69.54kBps.
    All our computers at home share a RoadRunner cable connection.
    Glad you got most of your new computer stuff working, Willow. Hope you get that DVD drive figured out!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • Willow
    It's a pain, I was just getting in the awing of things then the burner craps out. Looks like I will have to wait till Wed night to swap it.
