My SVS sub
dholmes
dholmes Posts: 1,136
Well I finally got to play with my new SVS sub, so far I love it!! I havent used the peq yet, just left it on min. Is the peq important, & how many ports have you svs owners pluged? I left all 3 unpluged. thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
  • PolkThug
    PolkThug Posts: 7,532
    edited November 2005
    :D
    Less plugs = higher amplitude and less extension
    More plugs = lower amplitude and more extension
  • BIZILL
    BIZILL Posts: 5,432
    pb12-plus/2 set up with only one port plugged @ 20 hz tuning. best for me by far. thought i'd plug two ports, but one port blocked was the best overall.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
    VR3 Posts: 29,697
    I would ONLY block one...
    Blocking two causes a wee bit of strain on the driver...
  • opus
    opus Posts: 1,252
    Remember positive SVS comments only. Preferably with lots of hype. All negative comments will be removed and the poster sacked.
    Thank you and good day :rolleyes:
    The Flea rig
    Hitachi 50VG825 LCD
    Rotel RSP 1066 (pre) :)-flea market
    B&K St-202 (mains)-flea market
    Carver M 200t (x2) (center and surrounds)-flea market
    Blu-Ray..PS3 (dvd player)
    Polk RTA-11t-flea market
    LsiC, Fxi30's
    Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
    Behringer Feedback Destroyer
    -flea market
    AudioAlchemy DDE v1.0 DAC-flea market
    Cambridge Audio Azur 640 CDP-flea market
    Signal Cable and Kimber Kable
  • faster100
    faster100 Posts: 6,124
    pics man
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Next to our SDA's,our SVS is the most cherished piece of gear we have...period.
    Good on ya,enjoy your new sub.
  • monkeyphant
    monkeyphant Posts: 79
    PB12-Plus. One port blocked at 20hz. Although, two ports gives me a flatter response,
    one port is best overall.
  • McLoki
    McLoki Posts: 5,231
    Mine is to boomy with nothing plugged. 1 port blocked gives me a nice flat response when room gain is added in. 25-31cs+ Just don't like the sound as much with 2 ports blocked.
    Michael
  • opus
    opus Posts: 1,252
    Michael
    +1
    kevin
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • monkeyphant
    Two ports blocked with the PB12-Plus is at 16Hz. There are very few DVDs in that range.
  • beardog03
    beardog03 Posts: 5,550
    Pc-Ultra...no ports blocked @ 20hz tuned, as per the little tag that camewith it..
    Now I`m thinking about plugging one port and going to 16hz..!!
    It say`s that "This SVS must have the correct number of foam port "blocks" and matching subsonic filter knob setting to avoid damage" on the toe tag that came on it.
    I thought about one port plugged @ 20hz, but it says "none" for 20 hz..
    whadda ya think..?
    Congrats on the outstanding purchase...I FRIGGIN LOVE MY SVS..!!
    It is the first real sub I have ever experienced...I want another to match it, but I digress..
    Mike Reeter,
    you have the same one I have...what is yours tuned at..?
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • Mike Reeter
    whadda ya think..?
    Mike Reeter,
    [you have the same one I have...what is yours tuned at..?]
    Same as yours,no ports plugged,20 hz. For our set-up,this seems to be perfect...
  • beardog03
    have you ever tried the 16hz tune..?
    w/one port blocked..?
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • Mike Reeter
    No,but you have me thinking about it...
  • beardog03
    I think I`ll try it..
    I guess it doesn`t matter which port is blocked , eh..?
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
