Need tons of power?
F1nut
F1nut Posts: 51,997
edited April 2024 in Clubhouse Archives
Very respectable amps at a very decent price. Will drive anything.
http://cls.audiogon.com/cgi-bin/cls.pl?ampstran&1137705844
No affiliation
OOPS, wrong section...sorry.
  • audiobliss
    audiobliss Posts: 12,518
    edited November 2005
    What would the output of these beasts be at 2 ohms?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • unc2701
    unc2701 Posts: 3,587
    They're series monobridged, so they won't do 2 ohm very well. I think you can send them to the factory and have them set up parallel- mono bridged, but you'll stay at 1200 watts into 2 Ohm.
    Backburner:Krell KAV-300i
  • audiobliss
    Ahh. The 2-ohm stability the seller was talking about must have been when they're in stereo mode. Sure does seem weird to have a monoblock that has a 'stereo mode'.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • unc2701
    Yeah, a lot of the uber-powerful amps are really just mono-bridged versions of the stereo ones. Sometimes you'll see them with series/parallel switches, so if you have 4-8ohm you can get more watts, but for under 4ohm you can get more current... I thought classe used to put one some of their models but I can't tell from the pics. F1- you know?
    F1nut Posts: 51,997
    Ah, no I don't. Best to contact Classe about that one. I know Bryston does.
  • TroyD
    TroyD Posts: 13,124
    The previous owner of my Classe Model 25 contacted Classe about running in mono into lower impedances....according to him, per Classe, they are stable at 2 ohm in mono. Also, they aren't strictly monoblocks, he has two stereo amps that he uses for mono operation. The back of each has stereo inputs and stereo outputs. They look exactly like mine.
    Take it for what you will, being second hand info, however, unless you've got a pair of Scintillas, I wouldn't worry about it.
    BDT
