New Arivals...
124»
  • dorokusai
    dorokusai Posts: 25,576
    edited November 2005
    No, an amplifier....that's what the original question was, correct?
  • Tour2ma
    Tour2ma Posts: 10,177
    Correct...
    I could have worded question a bit better... more like:
    "single speaker wired to amp's L+ and R- or vice versa."
    More later,
    Tour...
    Vox Copuli
  • dorokusai
    Are you suggesting an amplifier wired in monoblock configuration, or just miswired?
  • Tour2ma
    The latter... although at this point I'm not sure anymore...
    More later,
    Tour...
    Vox Copuli
  • kkowal
    kkowal Posts: 29
    Well problem solved got a adcom GFA 5800 250wpc nice still using pioneer sx1080 for preamp sda srs2 realy perked up thankx for the help every one.
    heiney9 Posts: 25,440
    Adcom's are great for sure......Make sure to check and see that it is a common ground amp. Most of the bigger amps have secondary windings which makes them NON-COMMON ground. You can possibly ruin your SDA's if you don't have the right cable (A-1 cable I believe). It's been mentioned on here that the GFA-5802 and GFA-5500 are NOT common ground.
    FWIW
