Energy Reference Connoisseur RC-10
cmy330go
cmy330go Posts: 2,341
edited February 2006 in Speakers
Just picked up a new pair of Energy Reference Connoisseur RC-10s The store I used to work at just started carrying them a couple months ago, and curiousity got the best of me. So I stopped in and bought a pair from a buddy that still works there (CP member Fireshoes).
I have had Energy speakers in the past and was always impressed with them for the money. When I first heard that the store had started carrying these I looked up the details on Energy's website. First thing I noticed was that the bookshelf model had approximately the same frequency response as the LSi9s I am currently using. This really peaked my interest since I tend to prefer the sound of monitors over floorstanders for 2ch listening, but don't like to sacrifice too much on the low end. When I first stopped at the store to look at them I was really taken back by their small size. They are only slightly larger than RTi4s. As soon as I saw them I was convinced that I had mis-read the stats.
Well it has been a few weeks since that visit, and I have decided to put my doubts to the test. I just set them up about an hour ago and already I am having to occasionally pick my jaw up off the floor. The punch these little guys have is breathtaking. Mids and Highs are nicely pronounced and detailed, but side slightly toward the bright side. I assume this trait will go away after a good break in. Now like I said it has only been an hour so far, and energy claims you should give them a solid 100 hours before getting optimal performance. So only time will tell. But anyway I was just so impressed that I had to post about them. I will post a more detailed review after a full break-in.
To anyone who has the opportunity to audition these I would highly recommend it.
Later ;)
HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
Post edited by cmy330go on
  • W WALDECKER
    W WALDECKER Posts: 900
    edited November 2005
    Later ;)
    they look very nice and i hope that the hot on the top initial impression is only temporary and the highs will smooth out for you. thanks....WCW III
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
  • steveinaz
    steveinaz Posts: 19,545
    Cool, looks very interesting...
  • Schris22
    Schris22 Posts: 983
    Cool I've seen a lot buy their Connoisseur and veritas but never their reference line! glad to see some personal experience.
    These are replacing your Lsi-9 right?
    I'm loving my energy connoisseur C-3's i just got
    Chris
    Receiver: Onkyo TX-SR502-S
    DVD Player: Pioneer DV-578A-S
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
    Subwoofer: 10'' Dayton 100 Watt
  • cmy330go
    Well sort of. I have them in place of my 9's right now. Honestly I bought them fully intending just to audition them and return them. I really didn't think I would like them enough to keep them. I mean how often are you likely to find a speaker at half the price that you like as much? But now I have a feeling when I return these I will be forced to order a set in a different finish. :rolleyes: Well I'll just have to see how it goes. Still got about 85 hours of break-in to go.
    HT
    2 CH
  • Schris22
    Schris22 Posts: 983
    hah nice good luck then!
    Chris
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
  • cmy330go
    Quick Update:
    Ok it's been about 60 hours of play time. I'm still loving these little guys. Side to side imaging is great. Depth is lacking slightly, but this is a problem I also suffer with the 9s. I'm sure this is due to having to place them too close to the wall. Bass response is still outstanding for such a small speaker. As expected lows have become cleaner and tighter with time. Mids and highs are also more mellow now. Still more forward than the 9's, but in my opinion not harsh in any way. So far I have found these to be a little more engaging and energetic.
    I'm waiting just a little longer before doing extensive side by side comparisons with the Lsi9s.
    Stay tuned. :)
    HT
    2 CH
  • audiobliss
    audiobliss Posts: 12,518
    I'm still tuned. :)
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • cmy330go
    audiobliss wrote:
    I'm still tuned. :)
    I'm a little delayed due to a failed tube in my amp. I just replaced it recently and am waiting to get it fully broken in again.
    But thanks for sticking with me.;)
    HT
    2 CH
