door pods for my 6.5" dx components
skydeaner
skydeaner Posts: 187
edited June 2006 in Custom Fabrication
Yo, I'm making 6.5' door pods for my dx component set and i am going to be blessing you all with pictures of my wonderful fiberglass work here soon... just thought I would prepare you. They will probably be crappy pictures, cause it was a real cheap digicam, but tell me what you think anyways... probably get them on here about 1am est
Fiberglass reminds me of peanut brittle, only fiberglass tastes better!
Post edited by skydeaner on
  • hellohello
    hellohello Posts: 428
    edited November 2005
    yay! pictures!
    Picking ones nose signifies a strong sense of self discovery :)
    System in the works: ;)
    PP 6V6 with 12ax7 pre ~ 20 watts
    15" Jensen MOD 8ohm ~ 97db SPL
    DiMarzio HS3 and/or Tone Zone S
  • skydeaner
    well there goes that idea, first of all the camera was broken, then i was so worried about doing everything correctly on these and taking my time so i dont have to do it again and I never did a test fit. and.... whataya know, the door doesn't close because the top part of them hit the dash... back to square 1 I guess.
  • skydeaner
    well I cut a section out of each side so they could fit, and then finally decided I don't care if the midbass's point toward me or not. I put them in the doors and pointed the tweets twards me and I am so completely satisfied... for jbl tweets that is. Now someone let me know of some good tweets that'll handle 100 watts
  • josh_parsons626
    josh_parsons626 Posts: 219
    edited June 2006
    Don't forget to look at My Home Theater :D
    Receiver - Onkyo TX-SR503
    Fronts - Polk Audio Monitor 40
    Center - Polk Audio CS1
    Surrounds - Paradigm Cinema ADP
    Subwoofer - Velodyne VRP-1200
  • josh_parsons626
    edited June 2006
    This is what I have right now in my 1993 Mazda 626. Rockford Fosgate tweeters But I'm pulling them to put in Polk Audio 6.5 Components. The Rockford tweeters were really clear and clean
