which amp to buy or suggestions
minime
minime Posts: 42
edited February 2006 in Electronics
Ive got a Denon 3802 and need to upgrade to a better amp to push my Lsi 25's. I like the nad T773 and im also looking at the Arcam Avr 300.Question whats the difference in a diva and just arcam avr 300.Seen the diva for 1600 and 1999. and prices on the arcam as high as 2500?The T773 i can get for 1299 anybody no a better buy or amp?
My denon was hit by lightning and mess up the rear channels so power amps are a down the road thing need a good amp 2000$ tops
Post edited by minime on
  • del44
    del44 Posts: 686
    edited November 2005
    Rotel makes a couple of good 5 channel amps. The 120 wpc RMB-1075 msrp for about a grand. And the 200 wpc RMB-1095 for under $2000.
  • beardog03
    beardog03 Posts: 5,550
    I have the same Denon, and I`m now using a Parasound HCA-2205a, but I was using a couple of Rotel RB980BX`s, and it sound Real good..
    I like Rotel and Parasound amps, and even though I have never experienced one, I hear Outlaw does a good job for a fair price..
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    Ok, first off are you wanting a receiver or an amplifier?? If you are looking for a multi-channel amp the B&K line is excellent, as is Parasound, you want something with high current for 2 grand at least 50-75 ampres. The more the better, look at the weights of each its a tip off these amps are heavy. I only mentioned two but their are just so many to choose from.
    If you are looking for a receiver, then the NAD, Rotel or Outlaw, dont think you can get a new B&K for under 2000 but they are excellent.
    You need to do some research but would be a nice time to upgrade from your Denon.
    RT1
  • minime
    minime Posts: 42
    I'm going with Arcam diva Avr300 this unit looks very nice and i found a place local who sells it for 1800 and for what your getting this is one sweet amp,anybody here have any arcam equipment? Thanks for your replys
  • BMc
    BMc Posts: 35
    I recently bought the Arcam AVR300 after trying out several other pieces of equipment at home including NAD separates, the Outlaw 1070, and tube amps. I find Arcam to have better definition than NAD. It's also a more expensive line of equipment but worth the extra expense. The FM tuner is much better than the Outlaw 1070. I no longer need a dedicated 2 channel system to enjoy music.
    The AVR300 amp has biamping feature that is unique for a AV receiver. I have assigned Channel 6 and 7 to biamp the left and right front speakers of my SDA SRS 3.1TL's. I'm using Monitor 7's for the side sourrounds, center channel and subwoofer set to none.
    Sony KF-50WE610 LCD Projection TV
    Dish 411 HD satellite receiver
    Arcam AVR 300 Receiver
    NAD 502 CD Player
    Toshiba DVD SD-3800
    front: Polk 3.1TL w/ RD0198-1 tweeter
    center: Polk CS350-LS
    surrounds: Polk Monitor 7C
    channels 6 + 7 set to biamp front
  • pjdami
    pjdami Posts: 1,894
    Cool. Good to see some folks getting Arcam receivers. Arcam is a well respected brand. I've been wondering how good their receivers are.
