Can hooking up 2 source-rigs to one set of speakers hurt?
jrlouie
jrlouie Posts: 462
edited November 2005 in Speakers
What if I want to run my Lsi15's in a 5.1 setup, and a 2-channel setup (don't have room for another set of speakers) with 2 pre's/amps? The 5.1 setup would have its own pre/amp/speaker wires going to one set of binding posts and the 2-channel setup would have it's own tube pre/amp/speaker wires going to the other set of binding posts.
Obviously the binding-post jumpers would have to be in place to get use of the full range of the towers.
I didn't know if loop/current could effect one or the other amps even if it was turned off, having just one amp on at a time. If that would be okay, what if you had both powered on at the same time, just only one source playing?
P.S. - I realize there are probably more optimal solutions: another set of speakers, a multi-channel tube pre with theater-pass, some sort of switch box, etc., etc. Just curious about the above scenario.
Post edited by jrlouie on
  • okiepolkie
    okiepolkie Posts: 2,258
    I would go against this idea.
    The safest thing to do would be just to unplug the set of wires you are not using. Just make sure the ends do not touch, maybe come up with an enclosure for one wire, so if one set is unplugged they do not touch and fry something.
    Zach
    Tschüss
    Zach
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    I smell smoke.
  • madmax
    madmax Posts: 12,434
    Possibly fire! No, you can't do that.
    madmax
    Vinyl, the final frontier...
  • jrlouie
    jrlouie Posts: 462
    Okay, appreciate the feedback. Figured, didn't hurt to ask. Now I know for sure.
    I can't wait until I move and get a little larger place ;)
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    I suppose it would depend on the gear. You would need a diode to act as a traffic cop and keep the current flowing one way only. Its just not a good idea.
    RT1
  • WilliamM2
    WilliamM2 Posts: 4,806
    A diode wouldn't work either, as the amps output is AC, it flows both directions.
    You could build or purchase a small switch box. Something similar to this:
    http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=300-571
  • unc2701
    unc2701 Posts: 3,587
    Just get a speaker selector, but wire it backwards.
    Backburner:Krell KAV-300i
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    To save your speakers, hook both sets to your fuzzy boys and run 'em both on high.................then report back to us tomorrow morning.
    I'll be anxiously waiting your report! :D
  • ND13
    ND13 Posts: 7,601
    WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!!!!!!!!!!!!!!!!
    What are you drinking/taking???? You need to share with the class. :D
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • Dennis Gardner
    Sometimes ya' gotta see things from that "live life to the fullest" point of view.
    We get too damn serious about building the perfect rig, and seem to lose focus of the fun that started it all. This is one of the only forums that isn't run by a bunch of elitist a**holes and humor tends to keep it loose. Just tryin to hold the status quo. ;)
    Cheers,
    DG
  • reeltrouble1
    ^^^^^^Right on Dennis^^^^^^^
    WilliamM2--the diode goes in the gear to protect it and regulate flow, the ac going into the amp is converted by the power supply to dc which ultimately powers the speakers, it was however a joke, just not as good as Dennis.
    RT1
    RT1
  • WilliamM2
    I'm glad it was a joke, but the speakers output is AC. DC current will fry them fairly quickly.
  • BIZILL
    BIZILL Posts: 5,432
    the speakers' output is sonic waves......... :rolleyes: sorry, had to.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • reeltrouble1
    William,
    I just dont get you man. First the amp output is AC, then the speakers output is AC, what you got something against DC. Here is Nelson Pass's diagram of an amplifier power supply circuit.
  • reeltrouble1
    As far as direct current frying up a speaker, well, seems like that kind of thinking overlooked at little thing called the transistor radio, right. So maybe we are talking this from two angles and meaning the same thing??? I suppose you are saying that the power is alternated inside the speaker to reverse the poles of the electromagnet, which is then AC.
  • opus
    opus Posts: 1,252
    Cheers,
    DG
    +1
    opus
    The Flea rig
    Hitachi 50VG825 LCD
    Rotel RSP 1066 (pre) :)-flea market
    B&K St-202 (mains)-flea market
    Carver M 200t (x2) (center and surrounds)-flea market
    Blu-Ray..PS3 (dvd player)
    Polk RTA-11t-flea market
    LsiC, Fxi30's
    Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
    Behringer Feedback Destroyer
    -flea market
    AudioAlchemy DDE v1.0 DAC-flea market
    Cambridge Audio Azur 640 CDP-flea market
    Signal Cable and Kimber Kable
  • WilliamM2
    Yes, I believe we are talking about the same thing. In the diagram you posted, as in most amp designs,coupling capacitors are used to block DC from reaching the speakers.
    The output from the amp is alternating current, it has to be, or the cone would only move one direction, overheat, and fry.
  • unc2701
    power is alternated by the input audio signal appplied to the tubes or transistors. that diagram is just the power supply end of an amp, not the output stage. the current coming out of the amplifier is AC.
