Can hooking up 2 source-rigs to one set of speakers hurt?
What if I want to run my Lsi15's in a 5.1 setup, and a 2-channel setup (don't have room for another set of speakers) with 2 pre's/amps? The 5.1 setup would have its own pre/amp/speaker wires going to one set of binding posts and the 2-channel setup would have it's own tube pre/amp/speaker wires going to the other set of binding posts.
Obviously the binding-post jumpers would have to be in place to get use of the full range of the towers.
I didn't know if loop/current could effect one or the other amps even if it was turned off, having just one amp on at a time. If that would be okay, what if you had both powered on at the same time, just only one source playing?
P.S. - I realize there are probably more optimal solutions: another set of speakers, a multi-channel tube pre with theater-pass, some sort of switch box, etc., etc. Just curious about the above scenario.
I would go against this idea.
The safest thing to do would be just to unplug the set of wires you are not using. Just make sure the ends do not touch, maybe come up with an enclosure for one wire, so if one set is unplugged they do not touch and fry something.
ZachTschüss
Zach -
I smell smoke.
Possibly fire! No, you can't do that.
Okay, appreciate the feedback. Figured, didn't hurt to ask. Now I know for sure.
I can't wait until I move and get a little larger place
I suppose it would depend on the gear. You would need a diode to act as a traffic cop and keep the current flowing one way only. Its just not a good idea.
RT1 -
A diode wouldn't work either, as the amps output is AC, it flows both directions.
You could build or purchase a small switch box. Something similar to this:
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=300-571 -
Just get a speaker selector, but wire it backwards.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
To save your speakers, hook both sets to your fuzzy boys and run 'em both on high.................then report back to us tomorrow morning.
I'll be anxiously waiting your report!
Dennis Gardner wrote:Can hooking up 2 source-rigs to one set of speakers hurt?
WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!!!!!!!!!!!!!!!!
What are you drinking/taking???? You need to share with the class.
"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
ND13 wrote:WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!!!!!!!!!!!!!!!!
Sometimes ya' gotta see things from that "live life to the fullest" point of view.
We get too damn serious about building the perfect rig, and seem to lose focus of the fun that started it all. This is one of the only forums that isn't run by a bunch of elitist a**holes and humor tends to keep it loose. Just tryin to hold the status quo.
Cheers,
DGHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
^^^^^^Right on Dennis^^^^^^^
WilliamM2--the diode goes in the gear to protect it and regulate flow, the ac going into the amp is converted by the power supply to dc which ultimately powers the speakers, it was however a joke, just not as good as Dennis.
RT1
RT1 -
I'm glad it was a joke, but the speakers output is AC. DC current will fry them fairly quickly.
WilliamM2 wrote:I'm glad it was a joke, but the speakers output is AC. DC current will fry them fairly quickly.
the speakers' output is sonic waves......... :rolleyes: sorry, had to.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
William,
I just dont get you man. First the amp output is AC, then the speakers output is AC, what you got something against DC. Here is Nelson Pass's diagram of an amplifier power supply circuit. -
As far as direct current frying up a speaker, well, seems like that kind of thinking overlooked at little thing called the transistor radio, right. So maybe we are talking this from two angles and meaning the same thing??? I suppose you are saying that the power is alternated inside the speaker to reverse the poles of the electromagnet, which is then AC.
Dennis Gardner wrote:This is one of the only forums that isn't run by a bunch of elitist a**holes and humor tends to keep it loose. Just tryin to hold the status quo.
Cheers,
DG
+1
opusThe Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre)
-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable -
Yes, I believe we are talking about the same thing. In the diagram you posted, as in most amp designs,coupling capacitors are used to block DC from reaching the speakers.
The output from the amp is alternating current, it has to be, or the cone would only move one direction, overheat, and fry. -
reeltrouble1 wrote:As far as direct current frying up a speaker, well, seems like that kind of thinking overlooked at little thing called the transistor radio, right. So maybe we are talking this from two angles and meaning the same thing??? I suppose you are saying that the power is alternated inside the speaker to reverse the poles of the electromagnet, which is then AC.
power is alternated by the input audio signal appplied to the tubes or transistors. that diagram is just the power supply end of an amp, not the output stage. the current coming out of the amplifier is AC.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
