denon dvd-2900 price
snakebitten
snakebitten Posts: 94
edited November 2005 in Electronics
can anyone tell me what the going rate is for a used 2 year old denon dvd-2900 is?
Post edited by snakebitten on
  • woodyjacobs
    woodyjacobs Posts: 706
    edited October 2005
    Probably around 250-300 US.
    system 1:
    Athena: AS-F1 mains, AS-C1 center, AS-B1 surrounds, AS-P400 sub, Yammie RXV-730, Rotel RB-976 driving front stage, Samsung BD3600 Blue Ray, Denon DVD2900 for sacd/cd , jbl n24awII on the deck, samsung 40" 1080p lcd
    system 2:
    XBox 360 Spherex 5.1 system, HK DVD38, Phillips CDC 926 CD changer, Phillips 32" LCD
    2 channel
    NAD 1600 pre, NAD 2400 THX amp, Phillips CDC 926, Linn extra speaks, crappy TT
  • PolknPepsi
    PolknPepsi Posts: 781
    edited October 2005
    I paid $600.00 for a new one about 3 months ago at closeout a price from an authorized dealer.....I would guess $300.00 or so.
    Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's
  • snakebitten
    edited October 2005
  • Jeffrey_B
    Jeffrey_B Posts: 21
    I also paid $600 for a new one about one month ago from an authorized dealer (who has since dropped Denon). On audiogon, they go for about $400 used.
  • lomic
    lomic Posts: 407
    Got mine on the Gon for $500 about 6 months ago, so around $400 now sounds about right. Luckily the one I got will play anything I throw at it, even scratched DVD's from Netflix. They're a steal at the current price - unless you realllllly need upcoverting HDMI video.
    Dodd Audio ELP [ Tubes ] // Harman Kardon AVR330 // Parasound HCA-1203A // Denon DVD-2900
    Polk Audio LSi9, LSiC, LSi 7 // HSU STF-2 // Signal Cable Interconnects (SG BW/A2/MP)
  • Jeffrey_B
    Jeffrey_B Posts: 21
    Hey IOMIC:
    I have the same LSi setup (LSi9, LSiC, and LSiFX) and am currently using my Sony ES30 receiver. I am looking to go with a separate amp and am strongly considering Parasound (the New Classic 5250). Did you ever run your LSis with a receiver prior to your Halo amp and if so, was there much of an improvement in sound quality? Thanks JEFF
  • dpowell
    dpowell Posts: 3,081
    Is this typical of Denon's players? I got my DVD-3800 for $299 from Tweeter a year ago and it complains anytime a disc isn't perfectly clean. Small scratches, prints and dirt cause skipping or a disc simply not loading. Maybe I need to use the 5 year warranty I bought and get it fixed?
  • polkatese
    polkatese Posts: 6,767
    I bought my Denon 3800 brand-spanking new in November 2002, and has start to acting up. The symptoms that you described above is actually very common problem. Right now, my Denon is possessed. Drawer ejecting in and out by itself. It takes a good 5-10 minutes before it reads any DVDs. I doin't think it's worth buying 5 year warranty on this machine, since it's been proven to have design flaw. Wait for the Blu-Ray player next year, would be my strategy.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • lomic
    lomic Posts: 407
    I'm running my LSi7 rears off my H/K 330 and it seems to do a fine job - the load on rear speakers is always so low I couldn't justify spending $150+/channel to drive them. I intentionally got my Parasound and LSi9's at the same time to avoid ever hooking them up to the H/K - because I only listen at high volumes anyway, I didn't even want to know how bad it might be.
    I did have one experience with an AVR + LSi15's at a Tweeter store. I wanted to see how an SACD would sound (before I got my 2900) on the LSi's so I asked the guy to pop in DSOTM. He used a mid-range Sony the drive the LSi15's and it was the worst thing I'd ever heard in my life - and the guy demoing it didn't seem to notice. I walked out of the room without saying a word after 5 seconds.
    Anyway, I'd generally advise anyone to get a seperate amp - though I doubt you'll hear much difference between a new and old Parasound, especially $1000+ worth. If you need GOOD looking components for WAF then Halo is worth the money, if not I'd say go with a used late 90's model off Audiogon.
    Nope, it seems to be a lot of Denons won't play scatched discs, which is why I consider myself so lucky ;)
    billbillw Posts: 7,799
    I just checked Ebay's completed listings (only goes back 2 weeks) and the price for a used 2900 is mostly between $400 and $500.
  • snakebitten
    Hey IOMIC:
    Yes, the amps make a big difference in sound. I was using the yame for all five lsi speakers. Then I bought a 3 channel (185@4ohms) b&k amp. Big difference. Last week I bought a b&k 2 channel(385x4ohms) and again an improvement in sound with all channels driven. I am very happy with the sound of the set-up now. Last thing I need is a good dvd player.
    hitachi 46f500 ws
    lsi9-lsi7-lsic
    b&k 2220 and st1430 series2
    svs 20-39
    panamax 4300ex
  • snakebitten
    sorry, fogot to include the word QUOTE above from Jeffery B
  • dholmes
    dholmes Posts: 1,136
    I have a perfect Denon dvd 2900 Ill sell for 450.00 delivered, orginal box & manuel.
    My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
    Over in the flea mkt, you said $400+shipping. What gives?
  • dholmes
    Sorry my fault, Ill take 400.00 + shipping. Sorry
