XRt12 XM Tuner. What is the best way to hook up?
jstereo
jstereo Posts: 1
Should I hook up the XRt12 XM Tuner via analog or digital? A Polk rep suggested digital but wanted to get other opinions. My current integrated amp (McIntosh 6500) only has analog inputs. Thanks.
Post edited by jstereo on
  • steveinaz
    steveinaz Posts: 19,545
    edited November 2005
    I tried my XRt12 thru my external DAC....Verdict? Because of the limited sound quality of the XM transmission, the tuner sounded essentially the same, but some "artifact nasties" were a little more noticable.
    In my system, the XRt12 sounds best on its own (analog connection). A good external DAC just exploits the signals weaknesses more. XM's sound quality does not do any justice to the Polk XRt12, I think the tuner is capable of some beautiful music given a better, less adulterated signal.
    Your better off going analog connection.
  • WilliamM2
    WilliamM2 Posts: 4,807
    The DAC in the XRt12 is supposed to be very good, so I would think analog would be fine. Sounds like you have no other option anyways.
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    Welcome to the forum,
    I have used my tuner in analog since I purchased it and don't plan on ever using the digital output. No problems. Hook it up and enjoy it.
    Mike
  • Willow
    Willow Posts: 11,231
    Bring that tuner to Canada !!!
