Denon AVR3806 4ohm?
edited October 2005 in Electronics
Looking at Denon AVR3806 receiver upgrade. Presently have Rti series 8 ohm drivers in 5.1 HT setup.
My question is………......... Would Denon AVR3806 by able to handle 4 ohm drivers if I would decide upgrade to Lsi’s in the future? The salesman told me it would by fine.
Theatre System 5.1
Sumsung HP-S5053 plasma
Receiver Denon AVR 3806 Pre/Pro
Parasound HCA 1500A amp (front L/R)
Parasound HCA 1000A amp (centre)
B & K AV5000 amp (bi-amp + surround)
Dynaco ST70 tube amp (Herbie HAL-O9)
polkaudio Lsi15 (Cherry) 2-channel
polkaudio Rti8 Front (Cherry)
polkaudio Csi5 Centre
polkaudio Rti6 Surround
polkaudio PSW1000 Subwoofer (Cherry)
Original A8T CD
Pioneer DV-275 DVD Player
MONSTER CABLE MP-HTS3500MKII Powercentre
Post edited by GATOR3000 on
Welcome!
    edited October 2005
    It's not rated to 4 ohm loads by Denon, just to 6 ohm. It will drive the LSi's "fine", just not very well because it's transformer and capacitors are not capable of delivering enough current without distorting. On the other hand, it does work very well as a preamp if you'd want to add outboard amplifiers later to match the more demanding speaker loads.
    There are plenty of threads answering this question. It's not something particular to Denon. Most mass market receivers have the same power supply limitations.
    edited October 2005
    Emlyn,
    Thanks for your info. The Sony I have now does not have pre-outs. That is why I’m upgrading to Denon AVR3806. Later on I would like to upgrade to Lsi’s and run them through external amp.
    For now I was wondering if the new Denon 3806 would drive Lsi’s.
    Theatre System 5.1
    Original A8T CD
    edited October 2005
    the Denon will work with LSI's, just monitor the volume. If you're running an lsi7 system you don't have to be as concerned about the 4ohm factor.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
    edited October 2005
    Well if its any conciliation, I use the Denon AVR 2805 (last year's model, a step lower then the 3805) and I've driven an entire 7 channel LSi system off of its internal amplifiers. After prolonged periods of high volume playing, it did get a bit warm, but it never shut down on me. Like someone else said, a high current seperate amplifier will make the speakers shine and bring out the best. And yes it does work nicely for a surround pre-amp.
    Give it plenty of ventilation (don't stack anything ontop), use only A OR B (NOT A and B) for the front channels, and don't get too carried away with the volume control and it will work acceptably.
    -Eric
    -Polk Audio
    edited October 2005
    I own a 3805 (same amp section as a 3806) and I own LSi's. I have run them directly off the amp and was FAR from pleased. I actually thought about getting rid of the LSi's to get RTi's because the sound was that bad. Now when I added a seperate amp... yummmmmm. The 3806 will make an amazing processor for the money, but don't use the internal amp if you plan on running LSi's. Take it from someone who has them.
Welcome!
Welcome!
