HELP - How do I replace my LSI9 Midrange?
ChicagoMike
ChicagoMike Posts: 17
I blew the midrange in my LSI9. I have the replacement midrange and I cant get the old blown midrange out of the speaker. I unscrewed it and it just wont come out.
Any suggestions anyone...?
ChicagoMike
Mike
Chicago, IL
Post edited by ChicagoMike on
  • Eric W
    Eric W Posts: 556
    edited October 2005
    6 screws around the front. It should drop out, you may have to pry a little. First try holding the speaker down towards a couch cushion and shaking it should wiggle out. If not you may have to pry. I recommend removing the tweeter (4 screws), and then you can get good leverage off of the baffle and the pry the midrange out.
    -Eric
    -Polk Audio
