CS300, NIB, $125 shipped....
RuSsMaN
RuSsMaN Posts: 17,985
edited July 2002 in Flea Market
Post edited by RuSsMaN on
  • har_navalta
    har_navalta Posts: 957
    edited July 2002
    Russ,
    That's not too bad for $99.97 Center Channel...
    a great deal!!!
    Har
  • RuSsMaN
    edited July 2002
    I had the 300 mated to an Onkyo rig with 800 mains, and ls/fx surrounds for some time. I actually preferred it's sound over the 400, its a good center.
    Cheers,
    Russ
  • mhw58
    mhw58 Posts: 359
    edited July 2002
    How big are the drivers on the CS300? Is there a website
    that has a picture of it?
    THanks, Mike
    Fronts: SDA1C's
    Rears: SDA2's
    Center:CS400i
    Sub: PSW505
  • RuSsMaN
    edited July 2002
    Polkaudio.com, dual 5.25 midbasses, 1inch trilam tweet, power port, single set of binding posts. There is a picture on the auction link also....
    Cheers,
    Russ
  • nascarmann
    nascarmann Posts: 1,464
    edited July 2002
    I basically the same as the CS245i....without blue drivers.....
    Oh, the bottle has been to me, my closes friend, my worse enemy!
  • RuSsMaN
    edited July 2002
    ...and with the rear 'power port'......
    -R
  • mhw58
    mhw58 Posts: 359
    edited July 2002
    I have Polk SDA2's as my front speakers. The Polk website
    says the CS400i is the best match. I can get a CS400 on
    ebay for around $200 or go for the CS300 for $100.
    What do you think I should do?
    Mike
    Fronts: SDA1C's
    Rears: SDA2's
    Center:CS400i
    Sub: PSW505
  • nascarmann
    edited July 2002
  • har_navalta
    edited July 2002
    Originally Posted by Russman
    Dual 5.25 midbasses, 1inch trilam tweet, power port, single set of binding posts
    With the Trilam Tweet, I will go with CS300...
    Har
  • mhw58
    mhw58 Posts: 359
    edited July 2002
    Why would you pick the 300 over the 400? Do you
    know if there is much difference between the CS400
    and the CS400i? From what I have read, they sound the
    same except the color of the drivers. How about the
    CS40i?
    THanks, Mike
    Fronts: SDA1C's
    Rears: SDA2's
    Center:CS400i
    Sub: PSW505
  • nascarmann
    edited July 2002
    Mike.....the 400 will work just fine. If you can get a deal on one......go for it is MO...
  • har_navalta
    edited July 2002
    I have CS400i, and my Sister has the CS300, it sounds almost similar to me...
    Har
  • RuSsMaN
    edited July 2002
    I bought the 400, and my friend bought the 300 at the same time. We demoed side by side on his Yamaha rig, and my Onkyo rig, I preferred the vocal clarity on the cs300, and thought the smaller drivers for center channel duty sounded more natural, less chesty. He thought the 400 had a better overall, 'bigger' sound. I swapped him my 400 for his 300 (and $50).
    Nothing is wrong with either one, a TON of members have the 400 here and would recommend it over the 300 or 245, but that's not how my ears heard it.
    Cheers,
    Russ
  • har_navalta
    edited July 2002
    If no one will get it, I might...
    Hey Russ, for $99... that's like a steal...
    Har
  • mhw58
    mhw58 Posts: 359
    edited July 2002
    I've had people tell me once I get the cable hooked up
    on my SDA2's, I won't need a center channel anyway. ;)
    My SDA'2 have 6 1/2 inch midranges so I wouldn't
    want to go with the CS300 if my SDA's would overpower
    it since 50% of the sound of most dvd's comes out of
    the center channel. I'll most likely go with the CS400
    but would love to hear more opinions.
    Thanks, Mike
    Fronts: SDA1C's
    Rears: SDA2's
    Center:CS400i
    Sub: PSW505
  • RuSsMaN
    edited July 2002
    Yeah it is, esp new in the box. They went for $299 back in the day.....
    I think it would make a great center for your SDA2's...I believe it was 90db 1w/1m, and if I'm not mistaken, your SDA2's are right there also.....
    Do what you feel comfortable doing, I'm sure someone will snag it up soon regardless.
    Cheers,
    Russ
  • har_navalta
    edited July 2002
    mhw58,
    I had these Polk Signatures for my Home Theater, but still
    I'm using CS400i for center...
    :D .
    Har
  • mhw58
    mhw58 Posts: 359
    edited July 2002
    Awesome setup!! How do you feel your 400i matches
    up?
    Mike
    Fronts: SDA1C's
    Rears: SDA2's
    Center:CS400i
    Sub: PSW505
  • RuSsMaN
    edited July 2002
    Har, get all that mucky muck off those speakers NOW!!!!
    You are hording SDA man, you shouldn't have 2 pair sitting there on the front stage..... Shame on you!
    Cheers,
    Russ
  • nascarmann
    edited July 2002
    Well.....at least there are no candles on them.......
  • har_navalta
    edited July 2002
    Those are my wife's favorite stuff... on top of them...and she said
    that it would look better more than plain.
    Har
  • vtec11
    vtec11 Posts: 82
    edited July 2002
    is it just me or are you using like a 13 inch TV with your setup ? hehe
  • har_navalta
    edited July 2002
    I remember...I'm not Wangotango's, that had candles on top of
    his SDA's............................................................sorry, Scott...
    :lol: ,
    Har
  • burdette
    burdette Posts: 1,194
    edited July 2002
    A couple of years ago my wife was having a gathering in our home (all guests were women). She lit a scented candle in a glass jar and set it on top of my .. I mean our.. 27" Toshiba TV. A little while later, a guest squawlked because the glass jar (inside) was on fire. It melted/buckled a section about 3" x 3", including a hole about 1/2" x 1" right through the top of the set. Um, we don't put candles on the TV anymore.... She knew within our first 2-3 dates that you do NOT set your drink on my speakers, and she's stuck to that one nicely.
    I have had to clean syrup off the front of a component, but I'm pretty sure that was my two year old.
  • jmasterj
    jmasterj Posts: 327
    edited July 2002
    Say vtec11, let's be nice!
    JmasterJ Polk to the Death
  • goingganzo
    goingganzo Posts: 2,793
    edited July 2002
    they would look beter if you swith the mains and go tall short tv short tall
  • RuSsMaN
    edited July 2002
    Looks to me as thought he has spaced them identically.....which I would prefer from a sound (sweetspot) standpoint...
    Cheers,
    Russ
    Har, get the **** off the speakers, they are not extra shelves for wifey-pooh's crap, period. They are loudspeakers, and damn fine ones, clean it up. ;)
  • har_navalta
    edited July 2002
    Hey Russ,
    It is my wife's idea so, personally I don't mind putting something on my speakers. It doesn't really matter to me because she didn't mind that I have HUGE speakers, so it matters less that she puts something pleasant on top of them.
    By the way the CS300 Center channel...
    Auction has ended with Buy It Now.
    Har
    "No matter what... (WAF)",
    ...I won't let mine go till the end of the world...
  • Frank Z
    Frank Z Posts: 5,860
    edited July 2002
    Har,
    My WIFE just stated that you've got to much crap on those speakers! She is a firm believer in keeping our HT looking like an HT, No baskets, plants, candles, or anyother asorted FOO-FOO-stuff! Not even a picture of her mother, my mother, or dear old Uncle Elmer!
  • har_navalta
    edited July 2002
    Well they're not there anymore... they are already packed since i'm moving. Besides I'm thinking of going to make the speakers not visible to anyone when I make a home theater in new home...
    Har
