DVD Recorders
Maurice
Guys, which vcr/dvd recorder would you recommend. I have several very important video tapes I need to save on dvds. thanks in advance for any/all help.
Everytime I think I'm out, THEY PULL ME BACK IN!!!!!!
Polk 70's,40,30's
Velo DLS 3500 Sub
JVC 61" HD-ILA
Sony DA4ES AVR
Oppo 981 DVD
Sony CDP-CX235 CD
Signal Bi-wires
AR ProII IC's
Polk 70's,40,30's
Velo DLS 3500 Sub
JVC 61" HD-ILA
Sony DA4ES AVR
Oppo 981 DVD
Sony CDP-CX235 CD
Signal Bi-wires
AR ProII IC's
Post edited by Maurice on
anybody
Polk 70's,40,30's
Velo DLS 3500 Sub
JVC 61" HD-ILA
Sony DA4ES AVR
Oppo 981 DVD
Sony CDP-CX235 CD
Signal Bi-wires
AR ProII IC's -
I'm thinking of picking up a dvd recorder sometime in the future. I usually check amazon.com and some other sites to get some feedback on the units.
The prices have fallen sharply and a dvd recorder and hd storage unit is actually within my means now.
Many dvd recorders will not copy videotapes with copy protection on the tapes so you may need to take that under consideration too.
Other options are a professional service to transfer your tapes to dvd, or use your computer and a video capture card and dvd burner. But only if you like fiddling with things. I do this right now and it's a bit of a pain but doable.
Good luck with your search.
regards
DaveTime is the best teacher. Unfortunately it kills all its students. -
Thanks.
I was going to use a service but I have about 60 tapes to dub. At $10 per, I could by a couple recorders. :eek:Everytime I think I'm out, THEY PULL ME BACK IN!!!!!!
Polk 70's,40,30's
Velo DLS 3500 Sub
JVC 61" HD-ILA
Sony DA4ES AVR
Oppo 981 DVD
Sony CDP-CX235 CD
Signal Bi-wires
AR ProII IC's -
Panasonic makes a nice one, i don't know the model#, though. It's in the $300 range. Sony makes a couple, also. I've always had good luck with anything Panasonic makes, videowise."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
I don't know if it applies to DVD, but Yamaha always had a VERY good reputation on their CD writers, in fact they were recommended by Stereophile for CD copying.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I have a friend that bought the top of the line sony DVD recorder 2 years back. It does a very nice job of copying. She did a copy of transfers from VHS for me and I was very happy with the quality.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
I have a Panasonic and it works great!
I've been hearing alot of good things about the panasonic. Sams has it for 278.00 so it looks like that will be the one. Thanks for the help guys.
Polk 70's,40,30's
Velo DLS 3500 Sub
JVC 61" HD-ILA
Sony DA4ES AVR
Oppo 981 DVD
Sony CDP-CX235 CD
Signal Bi-wires
AR ProII IC's -
Make sure you get one with a hard drive. I only save programs I want to watch again on DVD.
Maurice wrote:I've been hearing alot of good things about the panasonic. Sams has it for 278.00 so it looks like that will be the one. Thanks for the help guys.
That's the one!!
