Thoughts on Eosone
gacole2000
Hello,
I just got a deal on a pair of Eosone 350 surrounds at a local pawn shop. They have the center and a pair of 600 towers there in great shape and the guy is dealing. How do you think they would stack up to my RT55s and CS 400? Thanks for the feedback!
Greg
Greg
AVR: Yamaha RX-V661
DVD: Yamaha DV-C6480
BR: Samsung 1600
Mains: Polk RT55 (bi-amped)
Center: CS300
Sides: FX1000
Rears: RT/FX
Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
Projector: Optoma HD70 w/ 106" Elite Screen
Power: Panamax MAX 5100
Remote: Harmony One
BR: Samsung 1600
Center: CS300
Sides: FX1000
Rears: RT/FX
Remote: Harmony One
never heard them first hand, from what I remember, Eosone was made and or branded by polk just for Best Buy. As I said, I cant speak from experience, but I still feel confident that they will not be an upgrade. Might want to snag the towers and try though, whats the worst case scenario, you use them as surrounds and dump the eosone surrounds?Living Room 2 Channel -
Upstairs 2 Channel Rig -
