New or Refurbed?
MrNightly
MrNightly Posts: 3,370
edited October 2005 in Electronics
Here's the question:
A new Denon 3805 for around $750-800 or a refurbed one for around $650? What do you guys think? Is there that big of a difference? What is your experience with refurbed products?
I have no problem buying used, as long as it comes in one piece.
Holla back.
Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub :D:D:D
Denon 3805
Rotel RB-985 5-Channel Amplifier
Post edited by MrNightly on
  • jet2001
    jet2001 Posts: 180
    edited October 2005
    I own a referbed Denon and have no problems with it, cosmetically or otherwise.
    RTi4-fronts
    CSi3-center
    R15-surrounds
    Cerwin Vega LW15-Sub
    Denon AVR 885
  • Ricardo
    Ricardo Posts: 10,634
    edited October 2005
    My 3803 is "B" stock and I've had no problems with it..though I think that for $100 difference I would go with the new one.
    SOPA
  • maxima
    maxima Posts: 143
    edited October 2005
    If the price difference were greater, I would go refurb. In this case, the difference is only $100-$150 so I would buy new. Often times refurb gear has a lesser warranty than new. I have seen 90 day warranties on refurb gear quite frequently.
  • MrNightly
    edited October 2005
    Interesting... i guess i'll look at new. To the wife, tho... 100 bucks is HUGE. Crazy
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • audiobliss
    audiobliss Posts: 12,518
    edited October 2005
    Yeah, I was kinda thinking $100 is a large sum, too. But when you think about paying $650 for something that you're gonna keep and use a lot for quite a while that may or may not last and only has a 90 day warrantly versus $750 for something you know should work perfectly and if it doesn't has a long warranty period....it may be worth the extra $100.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • madmax
    madmax Posts: 12,434
    edited October 2005
    I'd look at used, personally. You can use it for whatever time period you wish then sell it for approximately the same price and move up the food chain with no wasted money. Everyone wins. You, the fellow you bought it from and the fellow you sell it to.
    madmax
    Vinyl, the final frontier...
  • MrNightly
    edited October 2005
    madmax
    What do you think about this deal?
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5820082218&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
    If that link works..
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • janmike
    janmike Posts: 6,146
    edited October 2005
    If you can purchase a new one for $750, why would you look at and used one for $700. Surely the 1 year manufacturer's warranty is worth that additional price. If I can purchase a used one for 75% or less of the retail value, I consider it. Other than that I, feel the risk is high, no warranty and then what. On the other hand buying from someone you know & trust is worth something. Just my opinion. Good Luck.
    Michael ;)
    NORTH of 60°
  • madmax
    edited October 2005
    If you really wanted the dvd player too it would be ok but I bet you can snag one cheaper if you keep at it. Overall about 50% of msrp seems to be an ok deal, %35 to %40 is normally what I go for. The best thing to do is keep an eye on them for a little while. Another thing I find is that the higher the class of component the better the deal you can find. For example, generally a $400 item may go for $275 whereas a $1500 item may go for $600. Look ahead at what you will be happy with 3 years from now and shoot for that if possible. It all depends on where you are headed.
    madmax
    Edit: Oh, a big part of deal shopping is to keep your eyes open for other options. If you focus too intensly on a particular model you more than likely will miss one three steps up going for the same price.
  • MrNightly
    edited October 2005
    madmax
    Excellent points. Thank you and they are well taken. I have been looking at Outlaw pre/pro but nothing used can i find anywhere... and i can't spend the money on a new one, out of my range at this time. So i am settled for a denon AVR. The 3805 fits my needs, tho the 3806 seems nice with special features i would use. I've expanded my searching for used to include these others... There is a NEW 3805 on ebay for $665 right now. That is just under the 50% you mentioned. Not bad for new eh? I'll keep looking. No rush to miss a good deal.
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • madmax
    edited October 2005
    It's mostly luck and having the ready cash when you run across something. For some reason it seems that when you really want something everyone else does too. I normally look for a little while then make my best choice. I've found deals that I could never find again but have also made a purchase and found it for much less the next day. No one is always lucky. :)
    Good luck!
    madmax
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2005
    I had bad luck with a Denon 2900 refurb, I ended up sending it back for a new one, now that is DVD not a receiver but for a measly 100.00 bucks I would get the new one. You should watch Audiogon.com for deals and to get a good feel for values, it costs nothing to look. The gear there and the people who do business there are generally a bit better than that on the E-Pay.
    RT1
  • MrNightly
    edited October 2005
    RT1
    I'll keep my eyes open... Thanks!
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
