Water in ATRIUM55's
gsummers
Earlier this summer I bought a pair of ATRIUM 55 outdoor speakers for our deck. Last weekend I decided to unhook them to bring them in for the winter. As I unhooked them, I discovered that there is water sloshing around inside them!
Is this a problem?
How can I empty the water out? Just turning the speakers over onto their tops does not do it.
Thanks for any insight you can offer!
Is this a problem?
Post edited by gsummers on
Call Ken Swauger at Polk, he will fix you up, they are not supposed to have water in them.
RT1 -
Thanks. How do I get ahold of him?
410-358-3600 ask for KenDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Hi, that is not normal. The #1 cause of water intrusion in the Atrium speakers is through the threaded inserts for the brackets. Making sure the knobs are tightly secure, or sealing the threads using teflon tape or thread sealer is a good idea.
In the mean time, you can send the speakers to our service center:
Polk Audio
2550 Britannia Blvd
Suite A
San Diego CA 92154
Include a note with your name, address, phone number, brief description of the problem and a copy of your sales receipt.-Eric
-Polk Audio
