Water in ATRIUM55's
gsummers
gsummers Posts: 2
Earlier this summer I bought a pair of ATRIUM 55 outdoor speakers for our deck. Last weekend I decided to unhook them to bring them in for the winter. As I unhooked them, I discovered that there is water sloshing around inside them!
Is this a problem?
How can I empty the water out? Just turning the speakers over onto their tops does not do it.
Thanks for any insight you can offer!
Post edited by gsummers on
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2005
    Call Ken Swauger at Polk, he will fix you up, they are not supposed to have water in them.
    RT1
  • gsummers
    gsummers Posts: 2
    edited October 2005
    Thanks. How do I get ahold of him?
  • hoosier21
    hoosier21 Posts: 4,417
    edited October 2005
    410-358-3600 ask for Ken
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Eric W
    Eric W Posts: 556
    edited October 2005
    Hi, that is not normal. The #1 cause of water intrusion in the Atrium speakers is through the threaded inserts for the brackets. Making sure the knobs are tightly secure, or sealing the threads using teflon tape or thread sealer is a good idea.
    In the mean time, you can send the speakers to our service center:
    Polk Audio
    2550 Britannia Blvd
    Suite A
    San Diego CA 92154
    Include a note with your name, address, phone number, brief description of the problem and a copy of your sales receipt.
    -Eric
    -Polk Audio
