Is it possible to damage a Harman Kardon 635 by using it with LSis?
Laura Palmer
Laura Palmer Posts: 124
edited October 2005 in Speakers
A friend of mine recently purchased the LSi speakers and I just wanted to test them out for a while on my AVR635....maybe do some A/B comparisons with the RTi speakers.
I know his speakers would sound best with an amplifier, but I currently don't have that resource. I just don't want to damage his speakers and/or my receiver. Would it?
Post edited by Laura Palmer on
  • Airplay355
    Airplay355 Posts: 4,298
    edited May 2005
    If you keep it at low volumes and in stereo mode you shouldn't hurt anything. Cranking it can result in the receiver overheating from trying to drive the 4o ohm load, and/or blowing the speakers because it will be pushed into clipping faster. The Lsi's are also less efficient so you aren't going to get the same volume as you would with rti's.
  • Laura Palmer
    edited May 2005
    How loud is loud? I usually listen around -35db on the RTis.
  • gregure
    gregure Posts: 871
    edited May 2005
    Originally posted by Zero
    Actually, the HK amps are very stable at 4 ohms and have no trouble pushing the Lsi's. In fact, they are one of the only receiver (sans chip amplifiers) of their class that I know of that can actually power the Lsi's well..
    Doubtful. The 635 may power the 4 Ohms w/o overheating, but I wouldn't go so far as to say they power the LSi's well. Does it make sound? Sure. Is it obvious even w/ a $1000 receiver that these are superior speakers? Without question. Does the 635 come close to revealing just how superior these speakers can be? Not even close.
    Happy listening, though. If your A/B comparison on a receiver at that level shows the LSi's off to your liking, at least you will know how they sound on a preliminary basis. I think you will find the sound qualities pleasing, although they will probably sound a bit thin or constricted on the 635.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited May 2005
    You may find this to be an expensive experiment. Once you hear them , even underpowered, there is a danger of wanting them all to yourself... And then a new amp, a new receiver, etc. Have fun.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Laura Palmer
    edited May 2005
    I know! The more and more I think about it, the more scared I get. I'm starting to think this A/B comparison is NOT a good idea.
    In fact the reason I wanted to borrow the LSis were actually hoping the opposite would happen. That I could put my fears to rest knowing I got better speakers for my purposes.
    Cause what led me away from the LSis in the first place was that I heard they were not good speakers if you listened to any rock music...and I do listen to some heavier "rock" type music... so I wanted to find some all-purpose speakers.
    Ah well...we'll see where I'm at in a few days. Whether I'm complaining that I picked up the wrong speakers, or if I'm excited that I made the right decision... It'll probably be the former.
    hee hee.
  • scottnbnj
    scottnbnj Posts: 709
    edited May 2005
    let the catcalls go up. if the tunes don't sound right with lsi's, give them a whirl with your preset eq trims. just remember that using them might put some extra strain on your gear, so take it easy.
    and have fun.
  • phuz
    phuz Posts: 2,372
    edited May 2005
    That A and B compariso with the HK will be fine, just don't push it too much. I had an HK AVR-510 at first with my LSis and it worked well, but I never drove the volume up really high. Never higher than 35 or so.
    Just keep in mind that those LSi speakers can sound a lot better. You might not believe it when you hear them but they can. ;)
    What kind of rock are you talking about? The LSi line is a bit revealing, so when listening to "metal" one might think it doesn't sound as good as an RTi or other type of speaker. It's not really the speakers fault, it's because a lot of "metal" CDs are poorly produced.
  • Tequila
    Tequila Posts: 104
    edited October 2005
    Ohhh, ok....the metal music has the fault....Come on...¡¡¡¡¡
  • LuSh
    LuSh Posts: 887
    edited October 2005
    The HK can power the LSI's...I have no idea why people are so scared. Yes it can dip down to 4ohms...its nominal is 6ohms in fact....and yes, even at higher volumes with the HK, I used a 635 and had the volume at -15 without any strain on a pair of LSi9's...its the pre/amp section of the HK that will diminish the quality of the LSi's long before the amp section.
    Also, the LSi's can play hard rock. Pickup a recording of Korn and crank it.
  • BIZILL
    BIZILL Posts: 5,432
    edited October 2005
    laura, if you're afraid you may become stricken with upgrade-itus, just keep in mind that there will ALWAYS be better than what you have out there. enjoy your rti's awhile before deciding to upgrade. let your wallet, well, purse stretch its legs out. (purse with legs?) :rolleyes: unless you can apply money spent on the rti's directly to a new set of lsi's, don't worry yourself too much. your friend will probably end up spending much more than you did for a little bit of better quality.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • ND13
    ND13 Posts: 7,601
    edited October 2005
    I'm with Zero and Lush on this one, and from personal experience. On occasion I'll even run the SDA 2Bs on the A channels and the RTA 8TLs on the B channels, at the same time, at moderate(-25 on the readout) levels, with nary a glitch or excessive heat. I've also ran a few other 4 ohm speakers on the HK without any problems at all.
    With that being said, of course an external amp running with the HK as a pre will take it up a notch, as long as it's a decent brand.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2005
    Its a bad idea because its not a good A/B test. Dont think it will hurt anything though.
    RT1
  • cfrizz
    cfrizz Posts: 13,415
    edited October 2005
    He didn't say that the music was the fault, he said that the production of the music was at fault.
    This is true of all music. If the production values are low it will show up with glaring clarity on better equipment.
    There are some of my discs I no longer listen to or have gotten rid of. I now hear lots of hiss, dullness, ect. through my receiver & separate amp that I never heard when the receiver powered the speakers by itself.
  • Tequila
    Tequila Posts: 104
    edited October 2005
    I did the test between Rt and Ls and the Rt won for me. Laura, Go for the Rt and don`t get a problem with the wrong LSi.
    I have two greats revelations in my life:
    1. God is not real.
    2. The Rti is superior than Lsi and nevermind the parts..to me.
    3. I am a free man.
  • ND13
    ND13 Posts: 7,601
    edited October 2005
    Tequila wrote:
    1. God is not real.
    3. I am a free man.
    Hmmmm..... :rolleyes:
  • DollarDave
    DollarDave Posts: 2,575
    edited October 2005
    Well...I guess he's 1) Pretty niave 2) Has a preference for the RTI speakers 3) Is a US citizen that lives in Mexico?
  • aaharvel
    aaharvel Posts: 4,489
    edited October 2005
    1. God is not real.
    3. I am a free man.
    word.
    and it's 'Naive' ;)
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • TroyD
    TroyD Posts: 13,124
    edited October 2005
    1. God is not real.
    3. I am a free man.
    While you can't really debate personal opinion I think I could make a pretty persuasive argument against all three.
    BDT
  • aaharvel
    edited October 2005
    BDT
    Word!
    WORD ON EVERYTHING!
    time to start a new thread, you guys know what's coming~ :D
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • Tequila
    Tequila Posts: 104
    edited October 2005
    Hey...
    My personal point of view is not for a fight... :rolleyes: Hahaha...Is not a problem.
    By the way...God is only in the mind. And nobody is truly free...
    Hey Dave...what do you mean in the third comment?
    Thanks. :p
  • TroyD
    TroyD Posts: 13,124
    edited October 2005
    rgr that...no worries.
    BDT
  • McLoki
    McLoki Posts: 5,231
    edited October 2005
    1. God is not real.
    3. I am a free man.
    Do we get to pick any two of the three??? :D:D
    Michael
  • aaharvel
    edited October 2005
    rock, paper, scissors
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited October 2005
    Laura:
    LSi's don't like H/K amplifier sections very well. THe combination can sound fairly dark and veiled. I've had no issues like that for any other amp/LSi combo.
    So while you won't damage them, the will sound poorer than they should, even for a receiver. ;)
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • cfrizz
    edited October 2005
    I went back & checked Laura's system. She purchased a 2 channel amp to drive her speakers. I don't know who dragged up this old thread from: 05-09-2005, 09:06 PM ! :confused:
  • ND13
    ND13 Posts: 7,601
    edited October 2005
    Our good Buddy Tequila drug this out of the abyss.
    Didn't Laura get one of the Monster amps??
  • cfrizz
    edited October 2005
    Jesus that explains it.
    Note to self Put Tequila on ignore list!
  • jdhdiggs
    edited October 2005
    Aww, caca, sorry Cathy, I saw it pop to the top and didn't remember the ancientness of the thread. Anyway, I stand by my point:
    Tequila makes one stupid.
  • cfrizz
    edited October 2005
    Amen JD!
    Noel, Yes she got a humongous 200 watt Monster amp for her RTI 12's. We helped her put together a slamming system!
