why tube amps are perceived "stronger" output than SS
  • audiobliss
    audiobliss Posts: 12,518
    edited October 2005
    So should I be able to hear when I'm feeding my speakers a distorted signal, even with a pretty non-critical ear?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • organ
    organ Posts: 4,969
    edited October 2005
    Audiobliss,
    You don't have to worry about clipping your tube amp when you finally get it. Your speakers are 98db/w/m. You'll blow your ear drums before the amp clips lol:D.
    Maurice
    SCompRacer Posts: 9,089
    edited October 2005
    organ wrote:
    However, a ss amp will sound more powerful on deep bass.
    I've got a tube amp here that changed my mind about that. Better than a Rotel RB-1090 anyway.
  • organ
    organ Posts: 4,969
    edited October 2005
    That's interesting. Which output tubes are you using? I've got EL34. I'll be upgrading the PS caps next and I hear this makes a big difference in my amp.
    Maurice
    edited October 2005
    Maurice
    Hi Maurice,
    My amp uses 40KG6A's. Horizontal output tubes. It's a McAlister Audio amp, made in Canada. :cool:
  • organ
    organ Posts: 4,969
    edited October 2005
    SCR,
    Awesome. Your tube type may be more powerful on bass. The EL34 is not known for bass extension. Hopefully, it will improve after some upgrades.
