please help: PSW 10 Sub
hello....could anyone tell me which is the PSW10 sub box volume/ frequency tuning? i would be really pleased.
Post edited by bladerunner on
  • Tritonman
    Tritonman Posts: 159
    edited October 2005
    http://www.polkaudio.com/homeaudio/products/individual/subwoofers/psw10/
    A good start.
  • bladerunner
    bladerunner Posts: 7
    edited October 2005
    well...with this info(outer length/width/depth..and the wood is 3/4 inch), and making some calculations, i can reach the internal volume(with some % of error, as the laminating and finishing adds to the total wall depth)but...which is the port lenght/diameter?or anyone knows which is it's tuning freq..
  • Tritonman
    edited October 2005
    Ya at a quick search thats all i came up with. I figured you would grab the measurements the way you did. Thats how i would have done it :)
    Hopefully someone here has one and can get the port lenght for you at least. Based on port length and dimensions you could get a rough estimate of tuning frequency.
