DIY Speaker Cable
NotALamer
NotALamer Posts: 4
edited October 2005 in DIY, Mods & Tweaks
I'm planning on making a Full Frequency Range Cable and I was thinking I might be able to make it more compact by removing the jackets on the individual cat5 cables. I don't see any reason this would affect the performance of the cable, and removing the jackets would make it much less bulky. Does this make any sense? I don't know a whole lot about speaker cables so let me know if I'm way off base here.
Post edited by NotALamer on
  • thehaens@cox.net
    thehaens@cox.net Posts: 1,012
    edited October 2005
    Check out this link , I got the same idea and made one years ago from this link and made one. I used 3 15 foot strands (after braiding it was about 12 feet long) and braided it. The cable isn't aesthetically pleasing to the eye, but if you have a few hours to kill try it out....
    BTW - I didn't notice any sonic difference from the cable I am currently using (Monster Z3) so I ended up tossing the CAT-5.....
    If you do a google search CAT-5 Speaker Cable you'll see a lot of instructions on this..
    scott
  • steveinaz
    steveinaz Posts: 19,545
    edited October 2005
    I wouldn't recommend that. The idea of leaving the strands insulated is to reduce "strand jumping." A type of Hyperlitz array so to speak.
  • mantis
    mantis Posts: 17,377
    edited October 2005
    I wouldn't waste my time trying to build something that has already been perfected at a good price.
    If this kind of thinking goes into your speaker wire, look no further then Kimber Kable 4pr or 8pr. Excellent quality wire at a great price. You can buy it in bulk or buy it terminated. Forget the cat5 speaker wire. It's been done in 1979.
    Dan
    Dan
  • steveinaz
    edited October 2005
    Dan's right, unless you just want to DIY for the enjoyment/satisfaction factor.
  • NotALamer
    NotALamer Posts: 4
    edited October 2005
    I'm building it because I like to DIY and it's a pretty simple project, not because I think I can drastically improve the cat5 speaker cable design or anything like that.
    When I said remove the jackets I didn't mean the insulation around the individual wires. There are three lengths of cat5 per speaker cable and each one has four twisted pairs with a jacket around it. If I remove the three jackets the individual wires will still be insulated, so it is still a Litz wire.
  • gidrah
    gidrah Posts: 3,049
    edited October 2005
    I built a couple of pairs of these and was pretty impressed. Not the best I've heard, but it was pretty inexpensive and kinda fun.
    Make it Funky! :)
