Another audio enthusiast stunned by the sonic impact T amp
ohskigod wrote:oooooops!!!!! I should have asked, but if I fried a 30 dollar amp, it wouldnt break my heart
sda 1b's only have one binding post, cant be biamped, unless you have something else in mind I'm just not picking up on. which is probably the case, beacuse you seem to be a friggin genius when it comes to doing stuff to electronics
Well, you could still do a form of monoblock right? -
they cant be bridged, so my guess is no. I've heard that if you only hook one channel and one speaker to it, it devotes all the power to that channel, by proxy making it a monoblock, but I'm not sure of the accuracy on that.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
Yea, one per speaker, that would do it.
madmax wrote:Yea, one per speaker, that would do it.
madmax
Does it matter to use right, left, or center channel?
-fredv- -
th sonic impact only has 2 channels, i cant imagine either one making a difference. you might be talking about the teac, which is a completly different ballgameLiving Room 2 Channel -
I found the following photos of a "heavily modded" T-amp on a Hong Kong website....
madmax wrote:Best thing to use is one of those small lead acid batteries then just recharge it now and then. I've had a few evenings of astonishment while listening to mine on the SDA-SRS. It has all the sound quality (maybe more) than some high quality amps, just at a much lower power.
madmax
I have a couple sealed lead acid 12v 9amp batteries that I use in my R/C plane flight boxes. Is that the style of battery that your are referring to? They are very similar to some motorcycle batteries.HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
That would work fine but is much bigger. The SLA batteries I was talking about are about 1/4th the size. Used in home alarm systems and such.
Oops, thanks. I mixed up 2 ampsohskigod wrote:th sonic impact only has 2 channels, i cant imagine either one making a difference. you might be talking about the teac, which is a completly different ballgame
-fredv- -
If you used two SI's as monoblocks and must have common ground it would be a good idea to use either both L's or both R's. The grounds end up referenced together because the L and R input grounds are the same and are hooked to both.
