Monarchy/SI integrated project
faster100
Ok yall know i got the Monarchy passive pre karma and i also have a sonic impact amp modded to a new case and stuff.. well tonight i decided to try something i been wanting to do for awhile.. Sonic impact amp integrated with monarchy passive pre with pass through output Rca's for a sub...
I essentially put my SI amp board, binding post, Led and power switch in the monarchy case. It now has 2 gold Rca inputs, one set of gold Rca outputs for a sub, and left and right amped binders from the Si amp. imputs on the right side.. all the rest in back. 12v power jack in back.. Blue Led in front and power switch on left side. I need to take pics shortly.. its real neat.
I want to paint the case hammered black to match my power supply i had for the SI amp which is being used for this also. sounds great, wish it wasnt passive in a way so it had more output voltage then what the source provides.
so now its a passive pre with integrated amp.. Oh and large volume knob on the front center of case.
will post pics when i get back
one question, The inputs are chained together inside. and when i hook the second source up and drops the volume out on the current source. do i need a rotary selector switch or can i just wire a off/on dual pole switch and drop the ground on one source to enable the other or what? lemme know
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
Post edited by faster100 on
pics to comeMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
inside guts, what a wire hole.. LOL
don't mind the ins/outs stickers they don't make sense now ive changed things.. those will be removed when i paint itMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Very neat project. I like it. Why don't you just use one source at a time. Once you add a selector switch, you're putting it in the signal path.
Maurice -
Its passive and minimal.. so i could just switch the IC's to keep it clean. I listen mostly to the FM tuner so it would be fine, By the way seen your thread on running 2 pre's.. so actually im just useing this old pioneer control pre as the input selector and then out to the SI integrated for now.. walaa i have both sources hooked up and even can control volume/inputs via my pronto remote..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
That's awesome. Do you plan to keep it that way? Actually, wtf was I thinking. Add the selector switch if you want. This isn't for your reference rig right?
Maurice -
Nah, this is a secondary rig... I sold my reference rig but it will be replaced next year some time.. this will suffice for now then get moved to the bedroom...MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Yeah, alot of it made it's way to the Indianapolis metro area :eek: , and more is still coming it seems.
"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
Couldn't think of a better person to have my stuff.. for now its novelty amps and small speakers
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
