amps
opus
opus Posts: 1,252
edited November 2005 in Electronics
I swore an oath to never again ask the noobie question of
"which _____ should I buy?",
so I will ask a little different question. In your opinion could an average guy (me) on average gear(mine) tell the difference between a used Carver (1.0 or 1.5) and a used Rotel 1080/ Conrad Johnson Sonographe 400?. I am in the used 2 channel amp market and had settled on the used Rotel/ CJ. But I am really happy with my Carver M200t(on center-lsic) and have read several glowing reviews of the Carvers. So if anyone has an opinion I would appreciate the thoughts.
I am using a Denon 3805 as my pre and do HT80%/ music 20%. Also I have Rti8's for now with lsi9's in the works.
Happy Wednesday...........kevin
The Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre) :)-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer
-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable
Post edited by opus on
  • PolknPepsi
    PolknPepsi Posts: 781
    edited October 2005
    I have different speakers but yes, I can tell a big difference between a Denon 100 watt receiver, a Sonographe 120 amp and a Carver 250 watt amp.
    .....and I consider myself an average guy too.... :D
    Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's
  • opus
    opus Posts: 1,252
    edited October 2005
    Sorry, I guess I could have phrased the question better. Instead of the old avr/ seperates issue I'm asking if I could tell the difference between a $200-400 Carver and a $700-900 Rotel or CJ. That extra 4 or 5 bills could come in handy elsewhere.
    Thanks to Club Polk I'm learning that bigger,flashier and more expensive is not always the answer. And I'm trying to get the most bang for the buck
    Go JoPa Go.......kevin
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
    SCompRacer Posts: 9,089
    edited October 2005
    Going by what I've had, the Carver TFM-35 amp sounds different than the TFM-45. The 45 follows the older M4.0t design, the 35 does not.
    Where abouts are you at in West Central Illinois Kevin? I could arrange a demo for you. I also have a Rotel RB-1090 for sale. :D
  • opus
    opus Posts: 1,252
    edited October 2005
    [/Quote] Where abouts are you at in West Central Illinois Kevin? I could arrange a demo for you. I also have a Rotel RB-1090 for sale. :D[/QUOTE]
    Oh really. I hadn't heard that. ;)
    I have been in a constant full court press on my wife ever since you posted the Rotel for sale. Times running out, maybe I will get lucky.
    kevin from Peoria
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2005
    Well, if you go for the CJ your 80/20 may start to change, held in very high regard as a musical piece of gear.
    RT1
  • scubamike
    scubamike Posts: 60
    do you still have your 1090 for sale and how much
    No, the 1090 is sold. Thanks for the inquiry though.
  • cmy330go
    cmy330go Posts: 2,341
    RT1
    To kinda go along with RT1's comment I would think the CJ would certainly have a more refined sound with music. But if you really don't think your 80/20 listening is going to change it may not be worth the extra coin. I honestly don't think HT listening would benefit much from the upgrade.
    Just my $.02
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
