Subwoofer Question
I accidently posted this question in the speakers section earlier . . . more appropriate to post here so sorry for the repeat. I have a velodyne va1215 subwoofer and the rubber surrounds around the driver are leaking air (small part has detached from the cone) I tried glueing that part down with rubber cement but that didn't hold very long. Velodyne won't repair it and said my only option through them is to buy a whole new driver. After searching online I have found a lot of companies that offer "re-foaming" for around $40-$45. Is this a gimmick or will the refoamed speaker hold (the sub hits somewhat hard as it has a 250W continuous/750W peak amplifier.) If anyone has had any experience with getting a speaker refoamed and could tell me if its worth doing or where to get it done I would appreciate the advice! Thanks.
Post edited by BURTON4273 on
  • beardog03
    beardog03 Posts: 5,550
    edited October 2005
    sounds like a job for sid....
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • BURTON4273
    BURTON4273 Posts: 7
    edited October 2005
    whos sid?
  • PolkThug
    PolkThug Posts: 7,532
    edited October 2005
    Try Superglue.
  • landry_p2000
    landry_p2000 Posts: 1,313
    edited October 2005
    I would probably go with a new driver if money is an issue. If not, get a new sub. If the super glue lets you down, this will be your only two options.
    Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
    Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD
  • Tritonman
    Tritonman Posts: 159
    edited October 2005
    Definately go with an new driver.
  • WilliamM2
    WilliamM2 Posts: 4,811
    edited October 2005
    Superglue may work, or you can buy something made specifically for gluing surrounds:
    http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=340-076
    You will need to get all the rubber cement off first.
