sda-1c cabinets
trdav1d
does anyone know were i can find a set of sda-1c cabinets? i do not care what shape they are in. or possibly know how to build some?
Post edited by trdav1d on
If you have the drivers and crossover already it would be reasonable to build a cabinent. What I've found is that you can almost always find a used complete pair in perfect condition for far less than the cost of the drivers alone. $400 to $700 complete. To build you will have to have the correct volume, the driver placement need to be almost exact and you will have to deal with tuning a passive radiator. On top of this you will need a wiring diagram and a crossover and drivers. You are going to have to do a LOT to be able to build them.
i have a complete set.the boxes were damaged by a moving company.i'm fairly good at woodworking and could duplicate the cabinets.i just thought if i found some i could refinish them because mine are beyond repair and building a new set i could do but it would be alot of work and i just want to get these awsome speakers back up and running as soon as possible! thanks for the reply. Troy
Where are you located? That might help your situation out a little bit.Tschüss
Zach -
Sorry to hear that the moving company ruined your cabinets. One consideration before you invest in a cabinet building project might be to make sure the driver voice coil magnets aren't damaged (dislodged slightly, causing seizing) from the pounding as well.
Good luck! -
what about that poser that was selling his SDA 1 something or another on EBay for parts...he sell them cabs or what?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
BlueMDPicker wrote:Sorry to hear that the moving company ruined your cabinets. One consideration before you invest in a cabinet building project might be to make sure the driver voice coil magnets aren't damaged (dislodged slightly, causing seizing) from the pounding as well.
Good luck!
+ 1 on that. I've been lucky and unlucky when it comes to the midbass drivers when shipped/dropped :eek:Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
my first concern was that my drivers were damaged so i took them to a local stereo shop and all checked out ok.i live in california.thanks guy's
