Signal cables?????
mantis
Can someone post in about these cables???Are they that good???
Id like to buy some just to try them out but would like to hear from some Signalcable owners.....
Dan
Post edited by mantis on
I own them and can report that they are much better than the monster, AR and AudioQuest that I have. Very transparent, very neutral sounding.
Russ has them, RonP has them as do others. Search the archives and you will find some good info.
Uh-oh! Mantis is going to attach them to his **** and test them (testing them out his ****). I wonder if there will be an impedence mismatch. I hear they can sometimes arc on an ****-hair.
Aaron -
LOLOLOL.
Honestly Mantis, if I was to bring them to a wire-shoot out, for my entry, I will put cold hard cash on the table that they will lay waste to any cable under $150~ or so.....(and they go for less than $30 a pair)...
Cheers,
Really?????
I tried the website but it was all effed up.Anyone with a link??
Does anyone carry them anywhere but online??What's the build quality like?
Do they make higher end cables?whats there top end line?Dan
Aaron,
thats was goodLOLOLOLOL!!!!!Dan
signalcable.com
Make sure you tell him you are from 'Club Polk' to get the group discount I arranged, its not much, but every $ counts......
Hate to quote Bowers & Wilkins, but with these cables, I have to.
'Listen and You'll See'....
Cheers,
I will attest that my Signal Cables laid waste to the Monster's I was using. I noticed two things right off. A stronger mid-bass punch and more detail in the high's.
I thought they sucked at first and you can read about why and what caused the problem in THIS thread.
I highly recommend the Signal Cables.
Peace Out~:DIf...
Ron loves a film = don't even rent. -
nevermind I got it.Dan
I guess you haven't read the other umpteen threads involving this cable.
Good luck on that shoot-out you've been promising!Make it Funky!
