Signal cables?????
mantis
mantis Posts: 17,370
edited July 2002 in 2 Channel Audio
Can someone post in about these cables???Are they that good???
Id like to buy some just to try them out but would like to hear from some Signalcable owners.....
Dan
Post edited by mantis on
  • TroyD
    TroyD Posts: 13,124
    edited July 2002
    I own them and can report that they are much better than the monster, AR and AudioQuest that I have. Very transparent, very neutral sounding.
    Russ has them, RonP has them as do others. Search the archives and you will find some good info.
    BDT
  • Aaron
    Aaron Posts: 1,853
    edited July 2002
    Uh-oh! Mantis is going to attach them to his **** and test them (testing them out his ****). I wonder if there will be an impedence mismatch. I hear they can sometimes arc on an ****-hair.
    Aaron
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited July 2002
    LOLOLOL.
    Honestly Mantis, if I was to bring them to a wire-shoot out, for my entry, I will put cold hard cash on the table that they will lay waste to any cable under $150~ or so.....(and they go for less than $30 a pair)...
    Cheers,
    Russ
  • mantis
    edited July 2002
    Really?????
    I tried the website but it was all effed up.Anyone with a link??
    Does anyone carry them anywhere but online??What's the build quality like?
    Do they make higher end cables?whats there top end line?
    Dan
  • mantis
    edited July 2002
    Aaron,
    thats was goodLOLOLOLOL!!!!!
    Dan
  • RuSsMaN
    edited July 2002
    signalcable.com
    Make sure you tell him you are from 'Club Polk' to get the group discount I arranged, its not much, but every $ counts......
    Hate to quote Bowers & Wilkins, but with these cables, I have to.
    'Listen and You'll See'....
    Cheers,
    Russ
  • Ron-P
    Ron-P Posts: 8,520
    edited July 2002
    I will attest that my Signal Cables laid waste to the Monster's I was using. I noticed two things right off. A stronger mid-bass punch and more detail in the high's.
    I thought they sucked at first and you can read about why and what caused the problem in THIS thread.
    I highly recommend the Signal Cables.
    Peace Out~:D
    If...
    Ron loves a film = don't even rent.
  • mantis
    edited July 2002
    nevermind I got it.
    Dan
  • gidrah
    gidrah Posts: 3,049
    edited July 2002
    I guess you haven't read the other umpteen threads involving this cable.
    Good luck on that shoot-out you've been promising!
    Make it Funky! :)
