Something special for you Carver fans
F1nut
A custom made center channel.
http://cgi.ebay.com/Custom-Made-Carver-Ribbon-Center-Channel-Speaker_W0QQitemZ5814719396QQcategoryZ14992QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
No Affiliation
No Affiliation
Post edited by F1nut on
I heard putting a ribbon sideways like that wouldnt fly too well. was meant to be vertical, hence sound quality, or probably the imaging, would be off. not that i would know for certain
I'll stick with my Polk's in the theater and my Carver's for 2 channel.
sure is intriguing though.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
Not sure Lou. The seller hangs on the Carver Forum and I've asked him if something was done to prevent the magnets from sliding out. No response as of yet.Political Correctness'.........defined
President of Club Polk -
You can throw a ribbon sideways. Looks neat, he's proud of it, that's for sure.
He paid too much, so you should too!Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
I don't know that it would sound bad. There is one channel of info, so it should work like any other center. Dispersion should be pretty wide.
That being said, it's nice but I'm not in the market. I'll stick w/ the 2 channel, and leave the Polks for my HT.
Is a little pricey, huh?
