Something special for you Carver fans
F1nut
F1nut Posts: 51,787
edited October 2005 in Flea Market
Post edited by F1nut on
  • ohskigod
    ohskigod Posts: 6,505
    edited October 2005
    I heard putting a ribbon sideways like that wouldnt fly too well. was meant to be vertical, hence sound quality, or probably the imaging, would be off. not that i would know for certain :confused:
    I'll stick with my Polk's in the theater and my Carver's for 2 channel. :)
    sure is intriguing though.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
    F1nut Posts: 51,787
    edited October 2005
    Not sure Lou. The seller hangs on the Carver Forum and I've asked him if something was done to prevent the magnets from sliding out. No response as of yet.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited October 2005
    You can throw a ribbon sideways. Looks neat, he's proud of it, that's for sure.
    He paid too much, so you should too!
  • amulford
    amulford Posts: 5,020
    edited October 2005
    I don't know that it would sound bad. There is one channel of info, so it should work like any other center. Dispersion should be pretty wide.
    That being said, it's nice but I'm not in the market. I'll stick w/ the 2 channel, and leave the Polks for my HT.
    Is a little pricey, huh?
